I use a 3 axis MAchine, wit Richauto Postprocessor.
The machine has a Rotary Axis along Y, (with name " C " axis on the hardware)
because the Richauto postpro you can find on the HSM fusion library is only a 3 axis postpro,
I find the RS-274D Autodesk multi axis
I tried to make a simple toolpath,
and become an Error when I tried to postrocess it
Error: Tool orientation is not supported for available machine axes.
Machine angles not supported: A-121 C-90
could it be link to machine configuration?
or Wehre can I find how to test my machine?
Must I edit the postprocessor?
I find the new training guide pdf about this process, but I do know wat to do with it
https://cam.autodesk.com/posts/posts/guides/Post%20Processor%20Training%20Guide.pdf
thanks
François Moreau
bénévole sur le programme Fusion:
Solved by engineguy. Go to Solution.
Not sure if the following is what you are looking for but here goes anyway. Have a look at the video first and if it`s what you need then have a look at the attached file and modified Fanuc multi axis Post Processor, hope it helps 🙂
thanks @engineguy
with the Fanuc rotatif I could edit a .nc gcode
I hope my Machine, Richauto, will understand it, I make a try and let it know if it turn how it must.
François Moreau
do not work. (but move, it is positive)
i made a small test without the 4 axis, with fanuc pp
it is working, look like ok. (I didnot take the time to mill it, but in the air it look it works normaly)
then I try the rotative test we speek about,
and it only move on the Y axis, nothing on the C axis (like it put everything together on the Y (Y+C) )
here small video of the problem
on this video I try my file 1003.nc, but I try also your 2009.nc with the same problem.
otherwise with the DSP B-18 Richauto handle,
clockwise is C-
so try I to adapt the Fanuc PP, or make other try with a other one? (witch one?)
good here continue to find the solution or post I the question on the autodesk HSM PP forum?
thanks
François Moreau
Thank you for the video, I can see that on your controller there is X/Y/Z and A axis, not C Axis, that is possibly why your 4th axis does not turn, I have modified the Post Processor to output A Axis moves instead of C Axis, as far as I know your RichAuto control should accept the Fanuc Inverse Time code so give the new PP a try, hopefully it will work this time 🙂 🙂
thanks, It's working much better
https://youtube.com/shorts/YjMcQnlA20I?feature=share
still not smooth, it make the first full round (A axis only turn) everything ok
then for the spiral it makes a lot off run stop on both Y and A axis
is it also possible that it run slowly as in the simulation ( about 1 minute in simulation (for the first toolpath and a second minute for the second), but much more needed I thing on the CNC)
François Moreau
