I just started editing my milling fanuc post processor
I am facing few issues
Solved by seth.madore. Go to Solution.
You've got 3 questions here:
1) The G17/18 you are seeing is because you've likely left the Lead-in/out to default values. There's a Vertical Lead Radius, and that will put the code into G18 mode and then back to 17 when it starts to cut in the X/Y
2) Are you approaching the cavity in a Xy direction, or are you 3D milling it in the direction that's shown in the image? Share your file please so we have better understanding.
3) Those are some simple post edits. I'll post back in a little bit once I get some other stuff sorted in my shop
that worked for me
just 2 more issues
edit: i am using 3d milling
pocket, contour and parallel operation
Sorry for the delay in response, this one fell off my radar. I've attached a Fanuc mill post that now has an optional stop and spindle off (m01 and M05) at the end.
