Hello m new to fusion 360 i used to work on UG NX before so i want to know which operations should i use now instead of contour roughing and surface area finishing with ball?
Solved by seth.madore. Go to Solution.
1. show pictures of your design
2. I think the question is better answered in the Manufacture Forum
günther
@Anonymous don't create a new post, I will move this one over.
Your roughing and finishing strategies are going to vary depending on the geometry and stock sizes. Generically speaking, 2D/3D adaptive are going to be your "go-to" approaches, and then 3D Contour, Parallel, Scallop for finishing. If you've invested in the Manufacturing Extension, then Steep and Shallow are going to be hard to beat
I am trying out different operations for now.
But i will need help editing the post processor.
