Message 1 of 8
2D pocket corner over cutting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Trying to use a 2D pocket for cutting timber rectangular shapes. If I use a 2D contour I get great results but below a certain size I need to use a pocket or similar to remove internal stock otherwise it'll grab the bit.
If I add a fillet to the corner in my model then the 2D pocket will be fine but for right angle corners I get the results in the picture. I'd like to understand why this is happening and what I could potentially do to fix it without having to edit the model.
The tool is a 4mm diameter bit. So expecting a matching curve on the corner to the bit but not expecting it to go further into the corner as shown in the picture.
