Lathe Problem with Tangential extensions
I noticed after the last update a problem with Tangential extensions for lathe. Since its a customer file I can not post it. But see pictures.
With out extensions on
With extensions on at .05 distance.
The back extension is fine. But the front extension is facing away from the chamfer.
If I use a larger number .1
Is there a workaround workaround? I know that a problem existed with the extension for the back. Support had a work around for the back. But it's not working for the problem with the front extension.
