2D Pocket Problems
2D Pocket Problems
andy.concept303
2D Pocket Problems
andy.concept303
Hi all,
Just come across an issue with tool not staying down while profiling a 2D pocket.  Have used this tool path and set-up many times before with no issue until now.  No matter what I seem to do I can't seem to get the tool to stay down, any thoughts?
F3D file attached.  Many thanks!
@andy.concept303
This any better ??
File included, combination of tool size, stepovers and height settings!
andy.concept303
Really appreciate the solution, but I'm afraid not, finish tool is a 6mm ball to provide floor surface (0.5mm stepover) and final fillet, and therefore need to finish with the tool up to the wall.  If I change to allow this, i still get the retract movements.
seth.madore
I would suggest using a Horizontal toolpath, followed by a spring pass with 2D Contour:
Seth Madore
andy.concept303
Thanks Seth, would you mind uploading the F3D?
seth.madore
Aww, cmon, it's a simple toolpath 😉
Seth Madore
andy.concept303
Seth, don't worry now sorted it, thanks!
