Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
2D Contour. Machining contour doesn't match model placement
6 REPLIES 6
mj.production
250 Views, 6 Replies
Hi there.
I'm working on a project using FM Gear generator.
When i try to select contours for machining, the contour where it'll machine is different to the model placement, which will cause it to machine to destroy my other parts.
I've grounded the model. The cog - seen on the pic - will select and place perfectly.
Hope you can help me
Best regards
Morten
Labels (1)
  • CAM
6 REPLIES 6
Sorry. Here's the reference photo.
seth.madore
in reply to: mj.production
Well that's curious. Can you share your file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
mj.production
in reply to: seth.madore
Hey Seth.
Sure, here you go.
seth.madore
Well, interesting. I'm not seeing that:
 What happens if you open up the .f3d and put some toolpaths on that file instead?
Seth Madore
mj.production
Hmm. It worked. How strange!
Thanks for the help 🙂
seth.madore
It's a hard one to troubleshoot, as it doesn't seem reproducible in a shared file. If I was a gambling man, I'd point you in the direction of using Joints to place your parts. I've seen this before with files that have many "Move" commands in the timeline.
Seth Madore
