I had this working, but not anymore.
Pls see set up; topalu op 2d Chamfer.
I have a countersink bit, that i hope will work for the chamfer.
I have selected various contours...with no luck.
The strange thing is the tool path shows an error
Warning: Empty toolpath. If you are machining a chamfer that is modelled, try setting the Chamfer Width and Chamfer Clearance to 0
I did that, but when I click generate I get a message
The selected operation has a valid toolpath.
Do you want to generate the operation anyway? I click yes with no luck.
Solved by engineguy. Go to Solution.
Try setting the Heights Bottom to the top face and not using the sketch, I turned off the sketch and selected the edge of the Model, works.
Your Countersunk tool works fine, also see the Chamfer width etc settings, hope this helps, see attached file.
Yeah that is what i needed. You showed me the outer edge chamfer, i was working on the countersink.
But the straight edge explained things nicely. Thank you much
