Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
2d Chamfer Help
2 REPLIES 2
jscott6SWZG
140 Views, 2 Replies
2d Chamfer Help
I had this working, but not anymore.
Pls see set up; topalu op 2d Chamfer.
I have a countersink bit, that i hope will work for the chamfer.
I have selected various contours...with no luck.
The strange thing is the tool path shows an error
Warning: Empty toolpath. If you are machining a chamfer that is modelled, try setting the Chamfer Width and Chamfer Clearance to 0
I did that, but when I click generate I get a message
The selected operation has a valid toolpath.
Do you want to generate the operation anyway? I click yes with no luck.
2 REPLIES 2
engineguy
in reply to: jscott6SWZG
@jscott6SWZG
Try setting the Heights Bottom to the top face and not using the sketch, I turned off the sketch and selected the edge of the Model, works.
Your Countersunk tool works fine, also see the Chamfer width etc settings, hope this helps, see attached file.
jscott6SWZG
in reply to: engineguy
Yeah that is what i needed.  You showed me the outer edge chamfer, i was working on the countersink.
But the straight edge explained things nicely.  Thank you much
Technology Administrators
