New to fusion so bear with me. Using a 2D adaptive path to rough a face with a boss in the middle, the tool path looks good until it starts to leave a thin strip of material begging to snap the cutter, is there a way to change the tool path ?
Hi @regank6SUZL and welcome to the forum.
It'd be good if you could share your project, so I can take a look and let you know how to sort this out.
Just export the f3d file and attach it to a reply in this thread.
Paolo
I'm not aware there is anything you can change with the adaptive toolpath to avoid that. Using 2D pocket machining will avoid a thin wall, but will take a little bit longer.
I selected the circle but then you need to click the red arrow to change it from inside to outside...
Not a problem. Yeah you're right it's not a great toolpath for harder materials. I mainly machine aluminium so I can get away with it.
I've definitely seen others with similar complaints so hopefully Autodesk might address this issue...
@dylan.smith - potential improvement to adaptive?
