Why no collision detection when using the boring operation?
Windylzy
Message 1 of 11
Windylzy
(view in My Videos)
As showed in the Video:
Collision detection not working when using the boring operation, but it's OK when drilling. Why?
Thanks!
Replies (10)
Message 2 of 11
a.laasW8M6T
It looks like its not detecting the collision because you have already "Removed" the material where it would collide with the drill, so there is nothing for the boring cycle to collide with.
You would see that if you turn of the model when simulating the boring toolpaths
Andrew Laas
Senior Machinist, Scott Automation
Message 3 of 11
Windylzy
Thanks for reply!
I've tried to remove the drilling, but the collision detection still not working when there is only the boring operation. Any idea?
Thanks!
Message 4 of 11
a.laasW8M6T
Hi
I'm not sure what the issue may be, are you able to share the Fusion file so I can take a look?
Goto File>Export>Save as .f3d/.f3z
Andrew Laas
Message 5 of 11
tessa.colledge
Collision detection has been added to all drilling cycles that are defined by opening a Drilling toolpath operation and then selecting Shaft/Holder collision detection. This will be available in private preview in the May release. We do not yet support collision detection on the Bore/Thread/Circular milling strategies.
Tessa Colledge
Senior Software Engineer
Message 6 of 11
a.laasW8M6T
Hi Tessa
It should still detect a collision in machine simulation though right, regardless of the toolpath settings?
I think that's what we are talking about here rather than the collision detection under shaft and holder
Andrew Laas
Message 7 of 11
tessa.colledge
That is a very good point. Let me alert a colleague who is knowledgeable about simulation to this thread, they will have more insight here than I do.
Tessa Colledge
Message 8 of 11
josh_orzech
Hi @Windylzy, I'm with the team working on machine simulation in Fusion. Can you share the project with me so I can bring it to the team for a closer look?
Josh Orzech
Senior Manager, Software Development
Message 9 of 11
Windylzy
Sure, I've added the file to the attachment. (test.f3z)
Thanks !
Message 10 of 11
a.laasW8M6T
Hi
The reason for no collision detection is that machine simulation does not currently simulate connecting moves between toolpaths.
The reason the first drilling toolpath is detecting a collision is that the second toolpath in that folder is selecting both holes therefore there is a linking move between them which is simulated
(view in My Videos)
Andrew Laas
Message 11 of 11
Windylzy
Thanks! I got it !!!👍👍👍
