What is the best post processor for generic Chinese mills (.nc or .gcode)
Alright, this is probably a silly question but some things aren't lining up so I just want to be sure.
I have a toolpath that I need to output to a flashdrive to put into my computer that is running Mach 3 and subsequently my CNC router. The website with router specs is: https://www.omni-cnc.com/product/sign-making-cnc-router/. Yes yes I know it's a cheap Chinese mill but you gotta do what you gotta do.
My router is the Omni 1212 and it states that the accepted post-process files are .nc and .gcode. But, when I go into post process for Fusion 360, when I select Mach3Mill, it tries to give me a .tap file.
Will that work? or is there a better post processor for this file type? If it means anything the controller is a "DSP Remote Controller  Weihong Controller Mach3" "WiXHC usb motion card".... and that's about as much as I can gather from it.
TLDR: whats a good post processor in Fusion 360 for a cheap Chinese mill that outputs .nc or .gcode toolpath files?
johnswetz1982
Well if it is supposed to use Mach 3 and you need a *.nc file extension you can edit the post processor file. Right at the top you can change the Extension="tap" and change it to "nc". Try that and see if you get an error loading it on the machine.
daniel_lyall
Mach3 can use .nc, .ncc, .txt and .tap
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
boardsbythebeard
Hi John,
How are you editing that code? I have the same issue that my mach3 post processor is putting out .tap files so my richauto controller wont recognize the file.
boardsbythebeard
Hi John,
I opened the file in text editor and changed ".tap" to "nc" that seems to have worked.
johnswetz1982
That particular editor is VS code. That is what you will see most of the people on here using. There is a HSM extension you can get for it and other CNC addons for it. People also use Notepad++. But do not use something like Word that will add in formatting that will corrupt the post processor or code.
daxpatel45
While using mach3  .nc   Will work Good With it.Fusion360 Gives Flexibility In Editing .nc files. don't worry go with .nc files.
