Vanishing file
Vanishing file
mike.chalifoux
Vanishing file
mike.chalifoux
Community Visitor
Community Visitor
Hi
I have a question about the AdCefWebBrowser application located in Username/appdata/locale/autodesk/webdeploy/(lots of numbers)/Win64.
I helped a friend load fusion 360 and he  was getting errors about a bad path to the above application.  I checked the path and found that the app was not there.   I have fusion 360 running on my machine ( both win 7 ) so I pulled my app and dropped it into the directory on his machine.
Here is the the strange part,  within a couple of seconds, the app disappeared.   I repeated this many time, checked permissions, made sure I was logged on as administrator, but each time I moved the app to the folder, it sat there for a few seconds then disappeared.
I guess I could uninstall and reinstall, but my last uninstall failed ( could not find uninstaller) so I erased all autodesk files ( nothing is the registry though)
Any suggestions?
Mike C
George-Roberts
I would advise a reinstall. When you uninstall Fusion, ensure you follow all of the clean uninstall procedure here: https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
If you struggle on any part of the uninstall, please post for assistance. Dont skip
mike.chalifoux
Community Visitor
Community Visitor
Hi George
I'll give this a try - It has a few step that I did not do. It will be a
few days from now. One note - when I tried this the first time, the
uninstall did not work - could not find the uninstaller file.
Cheers
Mike C
George-Roberts
Thanks for the reply. The clean uninstall steps should remove all required files (it should ask you to remove files / folders which the uninstaller should remove).
Keep us updated with how this goes 🙂
Cheers
jeff.walters
Mike what file is going away? i have seen something like this befor and it turned out to be there antivirus. could you have him disable his antivirus for a bit and see if the issue goes away?
Jeff Walters
Senior Support Engineer, CAM
