using a different offset for my probing result file
magdi_gomaa
magdi_gomaa
Hi everyone,
I have a question regarding probing and WCS behavior in Fusion 360 on a Haas mill.
My machining setup has always been based on G54. All generated motion/toolpath coordinates are relative to G54, and my probing inspection results were also reported relative to G54.
Now I received a new drawing from a client where the datum is defined differently: the origin is located at the center of the first hole, which is 13 mm away from my G54 setup origin. (as shown in the pic)
What I want to achieve is:
  • Keep ALL machine motion/toolpath coordinates relative to G54
  • Keep the actual probing moves relative to G54
  • BUT output the probing/inspection results relative to another coordinate system, for example G55
I hope that my question  is clear and hoping for a good answer
magdi_gomaa
 any ideas ?
UTD7ZNYB
You can just probe the hole in G54, set G55 based on that, and then run the inspection in G55.
lauri_barnhart
Hello @magdi_gomaa, we appreciate you posting your question.
Did the post by UTD7ZNYB help you and answer your question?
If this fixes the issue, please go ahead and accept it as the solution.
This ensures others can benefit from the resolution shared here.
If you still require support, please post an update so we can assist you further.
Lauri | Community Manager
