Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hi all
Needing some advice with respect to two sided milling.
Trying to complete my 'first' CNC guitar neck but second (back) side is different to the first (fretboard) side. They are offset to one another. The top surface of the guitar neck is off centre compare to the back side. hope that makes sense.
I have posted this on a fusion gitar forum and seems to be a common issue.
i'll try to explain.
The attached pictures show two neck models centred in my stock.
Registering pins in the stock.
I use the same CAM path to machine registering pinholes in my 'fixture'.
All my measurements indicate that everything is centred.
My process (at this stage) is:
- centre and secure the blank on fixture with tape/supaglue
- machine reg pins; then face; then trussrod slot; shallow outline contour to headstock height; rough parallel headstock; finish parallel headstock.
- turn blank over; locate on pins and glue down with tape/supaglue,
- machine tuner holes; outside contour to full depth; rough shaping across the neck; finish shaping pass along neck;
Take it off for the big reveal and the trussrod is well off centre (about 2mm or so)??
When i do the CAM for the top i hide the 'back of neck' model and set up all the CAM with visible fretboard sided model. Then vica versa for the back of the neck.
i have two different setups top & bak.
I was wondering whether i could put BOTH MODELS In the same setup??
All my thicknesses (z values) are pretty bang on eg headstock thickness, heel thickness etc.
My origin for the topside is centre of stock bottom.
My origin for the back side (inverted model) is centre of model bottom. Makes sense to me since the fretboard gluing area (top face of neck) is now sitting on the fixture.
I home my cnc at the start of each session. Jog it to the same offset centre of fixture and zero x&y as the origin. It lines up same point each time.
Sorry for the long post but it seems to make sense to me (newbie) but something is obviously not correct.
Any thoughts anyone? hoping there might be an explanation
Thanks in anticipation
cheers
