- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
***** newbie user of Fusion360******
Hello all.
I hope i have this post in the correct area, if not please let em know the correct area.
I would like to say hello to you all and hope I can get some advice.
I have been hacking at Fusion, watching many tutorials online for a while now, and I'm learning a lot, However
I have an issue that I cannot seem to find a solution to, here go's :
I have a design and I can have it designed in F360, I can get it to animate but when I take it into my plasma cutter its outer radius is 600mm as per the design but when it cut the inner circle it changes the cut like 1/4 moon.
the Plasma cutter is a CNC Macrocut Intercut 3. with a Hypertherm cutter.
if you wouldn't mind as to have a look at my attachments and hope somebody can help guide me in the correct direction.
If somebody uses a macro cut machine I would be eternally grateful if you can offer your advice or suggestions.
