Trouble altering machine config to work with post processer
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello there,
I have a part that requires a unique setup and I’m have trouble altering the machine configuration (specifically the kinematics) to work with my post processor. It seems that the alterations I make to the kinematics don’t affect the post.
I have a BC trunnion, and I’d like to shift the B home position -90 degrees making it parallel to the x axis. This would accommodate the length of the part.
To give some context I’ve attached a picture of the part:
The part is 24” long shaft with a taper and a keyway perpendicular to that taper. Ideally, I could just shift my home position for the B axis -90 degrees on the kinematics tab and that would be that. However, my post still assumes that the home position is parallel to the Z axis.
Any help would be greatly appreciated
