How would I go about creating a solid boring bar to use in machining to generate code
a.nekic
a.nekic
Hello all,
I've been using F360 for many of years now, my question may seem simple but to explain more. I know we have the option to create a custom insert and custom holders for our boring bars, but I've never really successfully done that when using solid boring bars i.e. P.H. Horn. Does anyone know of a good method of creating these because even with the tech docs of the bars, some of the info that F360 asks for I cannot input since I don't have that info. Thanks! (In case anyone wants to try, my bar that I am using is: R105.1813.2.3)
seth.madore
Solid carbide bars are a bit tricky to define. Typically, I'll create something that approximates something close, with the key data being correct. In this example, I've "defined" a Micro-100 Quick Change bar with an R.008 tip:
Seth Madore
