Torchmate "The vector to the center defines and invalid arc" error
I have a Torchmate 3 axis router that will not load cutter paths without giving and Error Code 1004: "The vector to the center defines an invalid arc. The arc cannot be drawn from the beginning point to the ending point with the center as specified." I have tried the torchmate post processor as well as the Fanuc. I have also checked the the controller is importing the arcs as absolute. Any help would be appreciated
serge.quiblier
Hello @Anonymous
Have you tested by checking this property?
It will generate the arcs in a different way, using a R value for indicating the radius, instead of defining the arc center via IJK variables.
Cheers.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
Yes, I have tried that. When I try that it gives me an "invalid arc" error.
serge.quiblier
Hi
Can you please share a gcode file with the problem?
Because the problem can be caused by multiple reasons.
It can be a missing IJK value when using the arc center.
It can be an accuracy issue, using not enought decimal places.
If can be caused by a too strict parameter on the controller, pretty similar to the previous cause.
So figuring this issue is not simple, without any sample code.
Serge.Q
cam.autodesk.com
