- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi ladies and gents,
I have to say in advance that I started using fusion only since a few months but I learned a lot thanks to the web. I am trying to mill a statue on my rotary axis. The file is an STL that I was not able to transform into a solid, because has too may faces. Facing and roughing with the rotary axis in adaptive mode is OK, but when I try to make the final pass with the rotary axis the tool is literally going through the body in two point, close to the feet and in the neck, the rest of the toolpath is fine. This happens not only in the simulation, but also on the real model, which luckily was made of wood, therefore I did not break anything. Please have alook at the picture attached. Any idea of what am I doing wrong?
