Tapered mill cuts into the body
Hi!
So my problem is:
I want to cut a contour with a 5.4 ° tapered bit, but the cutting head cuts into the body. How can I extend the contour so that the head does not cut into the body?
Tom.Hemans
Hi @Anonymous,
You can set a Stock to leave (in the Passes tab) that will move the tool away from the part by the distance set.
Hope this helps,
Tom
Tom Hemans
Technical Consultant
seth.madore
And if that doesn't solve it, can you export and share your file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Yeah, This solved it. Thanks 🙂
