Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Stock model turns black as zoom in
mattdlr89
Advisor Advisor
Message 1 of 8
mattdlr89
My green stock models turns black as I zoom into it and is unusable.
Is this down to settings or hardware issue?
I've attached a few screenshots as I zoom in. It has always done this in my limited time of using Fusion 360 (a couple of weeks). Although today it seems to be going black at a lower zoom level than previously. A little frustrating when trying to inspect the stock model.
Hope someone can help.
Replies (7)
Message 2 of 8
seth.madore
Change to these settings:
This is a long standing lighting issue. Using the settings above will greatly eliminate that
Seth Madore
Message 3 of 8
mattdlr89
Hi Seth
Thanks for your quick response. I made the changes it didn't have any affect until I restarted Fusion.
All seems to be good now I can zoom in further than I'd ever need to without the model going black.
Message 4 of 8
DarthBane55
@seth.madore
Seth, is that a fix for the %$#@$ easter egg?
Message 5 of 8
seth.madore
No, we're stuck with that 😉
Seth Madore
Message 6 of 8
DarthBane55
Message 7 of 8
martin.konarsky
I have chenged settings of Fusion, but it did not help. I am totaly disapointed and frustrated.
Does anybody have finaly solution?
Please have a look on videa attached.
thanks a lot
Message 8 of 8
martin.konarsky
Hello all,
I have found solution when this happens.
It works for me, please try if it does work also for you.
When the model turns black I have to change the camera from orthographic to perspective and then back.
When the model is reloaded (regenerated) the problem disappears.
Of course, this is not a solution, but it helps. I believe, that Autodesk team will solve the problem, sooner or later.
best regards
