Stability Issues...
Stability Issues...
LibertyMachine
Mentor Mentor
Message 1 of 166
Stability Issues...
LibertyMachine
Anyone else having serious stability issues? Prior to a few weeks ago, I could count on one hand the number of Fusion crashes I've experienced, and those I could always point to something stupid I was doing that lead to it. Now, I seem to be crashing at the least little thing. Go to Model, change a small feature, go back to CAM and click on the Setup. Freeze and Crash.
Open up an Operation, zoom in to select the proper chain. Crash.
Select a bunch of operations and CTRL+G. Crash.
Please tell me I'm not alone in this. You guys all know I love the software, so this isn't a rant, just more a plea out of desperation......
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Replies (165)
Message 41 of 166
justo_urbina12
I totally agree with you, however I would love to see a feature that traces an image for you so that you can just toolpath it, a feature that Vectric Aspire and Vcarve Pro have.
Message 42 of 166
justo_urbina12
Thanks, but I cannot open that attached file because it says opening local files is not supported.
Message 43 of 166
LibertyMachine
File > New File From Design > Search to where the .f3d is stored. Double click on the file.
I'd like to keep this thread focused more on Stability issues and less on miscellaneous functionality in Fusion, if you don't mind. By all means, feel free to start a thread that focuses on what you are trying to accomplish @justo_urbina12
Seth Madore
Message 44 of 166
justo_urbina12
Thanks, okay I will try it as soon as I can, sorry for jumping on your thread with something out of this topic.
Message 45 of 166
LibertyMachine
All good, I've done it myself before
Seth Madore
Message 46 of 166
bmxjeff
After 3 updates, I'm still getting crashes when I am editing CAM operations. If I slow down, it helps. Has this been logged or is there not enough information on the issue yet?
Jeff Hooper (Owner)
Hooper Machine and Design
[X] AUTODESK AMATUR ORDINARY
Message 47 of 166
Tianq
Hi mxjeff,
Did you send the CER when the crash happened? Or is it steady steps to reproduce the issue you have?
Dave
Dave (Qing) Tian
Message 48 of 166
bmxjeff
@Tianq
I have sent in about 20 crash reports on this issue. A few of them were very detailed. But I have not found a definite sequence to recreate the crash. It happens when I go through the CAM operations quickly to make edits and verify some aspect of them.  Clicking on the model, then the operations, then right click to edit. I'll try to get it to figure it out.
@LibertyMachine Has had this problem too. I don't know if it is still as issue for him or not. Thanks!
Jeff Hooper (Owner)
Message 49 of 166
LibertyMachine
@bmxjeff wrote:
@Tianq
I have sent in about 20 crash reports on this issue. A few of them were very detailed. ...
The problem still persists for me. I've found the best way to prevent them from happening is to SLOOOOOOOWWWWWW DOWN. No rapid clicking between processing toolpaths, leave the 3D mouse alone, deliberate clicking on everything, plus a little bit of luck.
Seth Madore
Message 50 of 166
bmxjeff
Do you have 2 monitors? @LibertyMachine
Jeff Hooper (Owner)
Message 51 of 166
LibertyMachine
Negative. One 24" asus monitor. I'd like to get a second one, but the desktop space isn't there at the moment. Once I find a new spot for the drill cabinet, I might add a second.
Computer is homebuilt
i7 4790k  4.00 ghz
Z97 motherboard
16gb (or 32, i forget) ram
2gb nvidia graphics
Win 10 (moment of stupidity)
Peripherals:
Monitor speakers, Logitech wireless mouse and keyboard, basic 3dconnexion mouse (wired)
Wi-Fi on the lower end of the signal, running through a booster. I keep on procrastinating on running a hard line. I know, with all the free time I have I shouldn't have an excuse /rollseyes
Seth Madore
Message 52 of 166
Tianq
May I know your email address written into the CER?
Dave (Qing) Tian
Message 53 of 166
bmxjeff
[email protected]
Just keep in mind, I was pretty frustrated. 🙂
Thanks!
Jeff Hooper
Backhand Bikes
615-275-9655
Jeff Hooper (Owner)
Message 54 of 166
Tianq
Understood, life is not easy. I feel frustrated as well when I see the complaints about the software.
Check the CERs from you and gearsoup, this issue is tracked with FUS-26603. Thanks for reporting this.
The issue relates with timer, which could explain why it works when you slow down.
Dave
Dave (Qing) Tian
Message 55 of 166
Tianq
FYI, FUS-26603 is solved in Sep. 7th update.
Dave (Qing) Tian
Message 56 of 166
LibertyMachine
@Tianq that is good to hear. I will give it a shot this weekend and see if it has indeed gone away on my end. Hear's to hoping!
Seth Madore
Message 57 of 166
LibertyMachine
Well, crashed 4 times yesterday. So, no, this problem hasn't gone away. It seems to be related to moving the Spacemouse and regular mouse at the same time. More specifically, the regular mouse over the design/CAM tree
In other news, I opened up an old file I made back in August and I was dismayed to see that all the operations were red, the stock was incorrect and my first 2 operations were on an old revision. I know for a fact that it was correct when I was finished with the job. I had a DMG Mori service guy at the shop yesterday and we were working on smoothing out the machine for adaptive cuts. I went to that file because I noticed the most issues on that part (machine issue, not Fusion). Old rev was 3 parts out of the material. That didn't work well for tooling, so I changed it to 2 parts (back in August). Opened it up yesterday and it was 3 parts.....
Seth Madore
Message 58 of 166
gerry_kmack
Yeah I crashed numerous times yesterday as well. The SpaceMouse does seem to be a factor, but not always. Some of the crashes occurred when I was not touching the SpaceMouse. One time I crashed almost immediately after having reloaded my design.
On the positive side, the most recent update did fix a lot of problems related to design changes not being properly transferred to CAM.
I really don't understand how software with this degree of instability gets released in the first place
Message 59 of 166
HughesTooling
I not sure about that I posted this last week, no response from support. Don't know if they missed it or it's already on there list so it's been ignored.
http://forums.autodesk.com/t5/computer-aided-machining-cam/bug-cam-doesn-t-update-after-components-m...
Mark
Mark Hughes
Owner, Hughes Tooling
Message 60 of 166
Steinwerks
Although I haven't experienced many stability issues (not using Fusion day in and day out like many here), I have heard from at least one person about them who is not active on the forums, especially dealing with moderate assembly size. This is a pretty big issue.
@al.whatmough @Tianq
Any news on this front?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
