Spun Profile not very accurate
monti.eng2020
monti.eng2020
Hi
Attached is a file with two components.  One is original and the other has the slots deleted.  There is a finishing ID profile cut on each component.  The toolpath on the original component isn't very accurate.  The component without the slots is perfect.  You can see this when you zoom in closer to the toolpath.  You can also see it in the g-code if you post process both profiles and compare them.
Is this avoidable?  Am I doing something wrong?
Marco
PS I'm still waiting with bated breath for the return of those handy incremental buttons that were removed a little while ago.  I really miss them. Thanks 🙂
seth.madore
It looks like the new "Spun Profile" option in Preferences is resulting in this inaccuracy. You can turn that off:
I'll pass this issue onto the appropriate team and get this logged as a defect, thanks for raising the issue! 
Seth Madore
seth.madore
I've logged this issue as CAM-46450, thanks for raising the issue with us!
Seth Madore
