Spiral option
Spiral option
dames123
Spiral option
dames123
Is there a 3d toolpath that can trace the center of a curve but has a spiral option? This is trace and it does what I want but it steps down instead of spiraling down.
Thanks.
a.laasW8M6T
Hi You could try 2D contour with the Compensation type set to OFF
Set multiple depths
And turn on Ramp in the Linking Tab
Andrew Laas
Senior Machinist, Scott Automation
Warmingup1953
2D Contour with ramp?
dames123
Thank you Gentlemen! I forget you can turn off comp completely in Fusion. I kept looking for the "center" option like in trace.
Thanks again.
oleg.tikhomirov
Hi @dames123,
Thanks for feedback. Sugestions above are really good and solve the problem, but spiral option for Trace is still valluable as this strategy might be used for 3D input curves, which are not supported in 2D Contour. I've crated ticket CAM-56139.
Oleg Tikhomirov
Software Engineer
dames123
Thank you Oleg!
