SPINDLE ROTATION LATHE
marcinkryszak75
Message 1 of 12
marcinkryszak75
While selecting off Clockwise Spindle Rotation, dump file still output "tool.clockwise=true". I know I can do some work around, but should this be controlled by that selector in Tool Manager?
Replies (11)
Message 2 of 12
Looking at tool data page, there should be check mark in that box for clockwise rotation. Operantly a bug because if box is cleared it should result in "clockwise=false" and output M4,.... which will crash tool on contact.
Message 3 of 12
marcinkryszak75
The problem I have, is that, I need to output M4 cus tool is lefty, and left hand tool setup for face groove in tool manager is something completly diffrent, meaning will cut on oposite side of the part.
Message 4 of 12
You are showing right hand tool in your screenshot, that runs with M3, clockwise as seen from back of the spindle.
I am still on old tool library, I cheat by using round shank because square shank has strait blade which crashes tool in simulation.
These would be my settings for LH face grooving tool.
When mounted on back turret, cutting edge of insert faces operator and spindle runs CCW (M4).
2021-01-28 07_38_28-Library _ [Untitled].png2021-01-28 07_38_49-Autodesk Fusion 360.png
Message 5 of 12
marcinkryszak75
When I'm using left hand setup, I'm getting this...
Message 6 of 12
Starting to look like cat and mouse game, can you share your file?
Message 7 of 12
marcinkryszak75
Sure, I think it's a bug inside CAM. I have check with other strategies and tools (mills, drills, borings), when tool is set right handed and spindle rotation is clockwise OFF, dump output is always clockwise=true.
Message 8 of 12
You used turret 1, should be zero for back turret, then tool orientation is correct.
Message 9 of 12
Ops, tool was moving sideways into the stock, not good for its health, this looks better.
Message 10 of 12
marcinkryszak75
It works. I don't know how. I'm trying to replicate, but can't. It has to be some sorcery.
Message 11 of 12
marcinkryszak75
Got it. start from creating new tool, and make it left hand and turn off clockwise rotation.
Message 12 of 12
Also, in last tab of tool definition, make turret number zero, not one as you had it in original file.
