Specifying Creation Time at the Beginning of an NC File
kwebek69GNU5L
kwebek69GNU5L
Hello!
How can I change the Fanuc.cps postprocessor file so that at the beginning of the NC file, along with the tool information, there is also information about the creation time of this NC file?
For example
programming2C78B
before //tool information, add
if (writeDetails) {
writeComment("Posted: " + getGlobalParameter("generated-at"));
Please click "Accept Solution" if what I wrote solved your issue!
kwebek69GNU5L
Hello! It's great that you can implement this idea! Could this be what it looks like?
But in this version an error occurs ... What did I write wrong?
programming2C78B
Im not sure, maybe there is a detail field you must also add or something. Here is my mill post that includes it. You can root around and try to see what it's using with the fusion360 plugin for Visual Studio
kwebek69GNU5L
Fusion 360 reports an error when loading your post into Post Library...
