Global toolpath name change is erratic
tgford58
tgford58
This came up on an earlier post that I made but I just had a global toolpath name change occur without selecting any of the affected names.
I made a quick change to the first toolpath, increasing chip load.  When I accepted the change all of the titles had changed.  Easy to back out of the issue but I don't understand what I am doing that creates this global change.
Can someone give me a clue on how I can control this option?  It's useful but only when I know it's coming.
Camtech-CezayirYasa
I made a video for you in the hope that I understood your problem correctly. You may have done like me during the election.
seth.madore
There is certainly a lot of flakiness around the naming of toolpaths and setups currently. We have a fix that addresses most of this, but it won't be going out until the next major update, which is not going to be for a bit..
Seth Madore
tgford58
Best I can figure out is I select an operation after I post or simulate and though only the op that I am highlighting is opened, when I close it changes them all.   If I click on the workspace before I select an Op to change it does not happen.
An annoying thing sort of on par with the window expansion cursor not going way when you have an op opened for edit.  The cursor works the same but the icon is the double bar with arrows icon.
Thanks @seth.madore and @Camtech-CezayirYasa   I'll wait for the next major to come.
