Setting up a mill-turn machine with dual spindles, upper milling head, and lower turret
MasterMXX
MasterMXX
Hi, I'm trying to set up a mill-turn machine with dual spindles. The upper head is a milling head with a 240-degree rotational axis, and the lower head is a turret with movements in the XYZ axes. I selected "Generic Dual Spindle Y-Axis Lathe with Live Tooling," but I can't figure out how to add the upper milling head.
Does anyone know how to do this?
a.laasW8M6T
Hi
I don't believe its possible to setup a machine like this in Fusion
Fusion doesn't Support Multi channel machines at this time.
The best you can get is to set it up like this without the Turret.
Also be aware that Turning is not yet supported for Machine Simulation, You can do milling Machine simulation though
Andrew Laas
Senior Machinist, Scott Automation
seth.madore
@a.laasW8M6T correct, this machine is not supported.
@MasterMXX To work around this limitation for now, you should define two separate machine configurations.
Seth Madore
MasterMXX
How did you change from "turret" to "head"? This option is grayed out for me, and I can't select it.
MasterMXX
@seth.madore Alright, thank you! I'll give it a try.
