Second value treated as mm despite being in inch mode
eerier_bleach0f
eerier_bleach0f
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
seth.madore
I think this is expected. In the first part of your math, you've specified the units (-.33 in) but the second part (.125) is unitless.
What do you get when you have -.33 -.125
Seth Madore
eerier_bleach0f
There's no way you aren't trolling lol.
Default units in both Design and Manufacturing are set to inches:
Screenshot 2024-06-07 at 8.38.07 AM.pngScreenshot 2024-06-07 at 8.38.11 AM.png
I'm in inch mode and it's set as the default:
Surely every number I input should be assumed to be in inches unless I specify otherwise?
I brought this up regarding the tool library a few years ago and it was either agreed it should be changed or it was already a known issue I can't remember.
Why would it make sense that Fusion would correctly assume the first value is what the user set Fusion to but then just change the second to mm?
How is this not ripe to make users make accidents? I'm always double checking stock size and going "...why is my stock .37189834" thick? Oh..... It wasn't enough that I told Fusion once what units I want...
Fusion specified the units. Because I'm in inch mode. I never typed "in". I would have just typed "-.33"
.325, treats second as mm.
There's no way you aren't trolling?
programming2C78B
I agree that this is an error/issue, but why are you inputting units in at all if you know there are 3 different areas with it all set to IN? Why even do that math inside the field?
Please click "Accept Solution" if what I wrote solved your issue!
eerier_bleach0f
Not sure what you mean in your first sentence but IDK. I need to do math. Sometimes I use the calculator app on my Mac, or the one on my iPhone. Fusion lets me do math in those fields so sometimes I do lol.
