Message 1 of 8
Second milling operation doesn't mill correctly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have attached the file in question for your review. I have a simple 2 pocket milling operation of 2 different size pockets. The first (bigger) pocket mills fine. When going to the smaller pocket, the machine only mills down 4.6 mm. I have the second operation set up to mill starting at 9 mm down, in 3mm deep passes, and I have chosen the bottom of the model as "bottom"plus .5 mm. So, it should mill down 10.5 mm. The stock is 19mm thick.
I have ran the simulation and it runs fine on both operations. I have re-looked several time at my settings and don't see anything wrong.
Can you please assist with why the second operation does not mill correctly?
Thank you fro your time.
Bill
