I was wondering if this is what you at Autodesk intended. Changing the conditions for Free Fusion360
(WHEN USING FUSION 360 FOR PERSONAL USE, THE FEEDRATE OF RAPID MOVES IS REDUCED TO MATCH THE FEEDRATE OF CUTTING MOVES, WHICH CAN INCREASE MACHINING TIME. UNRESTRICTED RAPID MOVES ARE AVAILABLE WITH A FUSION 360 SUBSCRIPTION.)
As can be seen in the attachements, the result of moving between 4 holes for drilling the speed is set to ZERO.
It took a while before I discovered that the reason for no movements at all of my CNC where the F0.]
Please help, if this behaviour is intended I do not understand you anymore.
