Romi M17 with Fanuc 21i-T
curtis_hervi
Message 1 of 10
curtis_hervi
Does anyone have a post for this setup?
Pretty new to CNC and hoping to cut down on the modifications needed from another post. If any.
thanks
Replies (9)
Message 2 of 10
seth.madore
Can you describe the options that come with your machine? Is it just a 2-axis lathe, or is it a twin spindle C/Y machine with live tooling, part catcher, the whole works?
Seth Madore
Message 3 of 10
curtis_hervi
Seth,
It's just a single spindle X,Z 2 axis machine with an 8 position tool changer and a single flood coolant pump. No parts catcher or live tooling.
Message 4 of 10
seth.madore
Do you have any code you know works well in the machine? It's likely that we're just going to point you at the generic Fanuc turning post processor, and it's also likely that it will require some edits to make perfect. Most edits can easily be done, while some others can be quite involved. YMMV
Seth Madore
Message 5 of 10
curtis_hervi
Not yet. I figured the generic one would need modified and hoped someone had already done it.
We'll give it a try and see how it goes.
Message 6 of 10
antitankrifle
Community Visitor
Community Visitor
Hey wondering if this was ever figured out, I have the same machine, cant seem to find any information on the post used, or the editing to make it work with the older machines
Message 7 of 10
hugh_granger
This is the post I use and have modified. If that helps at all. @antitankrifle
Message 8 of 10
antitankrifle
Community Visitor
Community Visitor
Hey thank you so much, I will try it out, and see if this works for my machine
Message 9 of 10
servicesU63UK
Community Visitor
Community Visitor
Did that work for you? I'm in the middle of purchasing a 2000 Romi M17 with Turret.
Message 10 of 10
CNC_Lee
@curtis_hervi @antitankrifle @servicesU63UK
If the generic Fanuc or above post is not providing the required output, I offer post processor development services and happy to work out a solution for your machine! Message me if I can be of further assistance.
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
