Rest rough from STL file not working
Ariel
Message 1 of 8
Ariel
I had a look through some old posts and there were comments about it being removed and then reinstated, thanks to @Anonymous
I follow the NYC CNC procedure but the rest rough operation ignores the "from file" STL and results in just a normal roughing operation without consideration to the STL.
Is anyone else experiencing this?
Screenshots attached of operation "2" & "3"
Ariel
Replies (7)
Message 2 of 8
Same issue since reinstated,
Message 3 of 8
Ariel
so they have removed the functionality again?
Message 4 of 8
daniel_lyall
It is still there did you have the stock turned on when you ran the sim to get the stock model
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 5 of 8
Ariel
Yes  I sure did. I went through all the operations and regenerated them and still no luck
Message 6 of 8
seth.madore
Is this a file you can share?
Seth Madore
Message 7 of 8
Ariel
Same file if you have access to the case?
Message 8 of 8
seth.madore
I do not. Salesforce is another department that I don't have ready access to
Seth Madore
