Rest Machining Turning
Message 1 of 10
Rest machining appears to not be fully working when turning and therefore a lot of time is wasted.
I have apart that is reduced in the middle, I clear a lot of material out with a triangle tip and then move to a grooving tool with a R1.5mm tip,using sideways turn groove.
The grooving tip spends a lot of time cutting material that has already been removed in the previous op, the rest machining option is turned
on.
Any ideas?
Replies (9)
Message 2 of 10
Steinwerks
Hard to tell without seeing the file. Is it possible to export it and share it here?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 10
sure .f3d file attached
Message 4 of 10
HughesTooling
Seems to be a problem with grooving, if you set up a tool to cut from back to front it works fine.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 10
How odd, if you set grooving to be full step down instead of sideways it also works.
Surely this is not by design? - Will report as a bug.
Cheers
Paul
Message 6 of 10
Hi @al.whatmough is this a bug ?
Message 7 of 10
jeff.pek
This does appear to be a problem in the software. We are investigating.
Thanks for reporting.
Jeff
Message 8 of 10
jeff.pek
We have confirmed this as a defect, and are tracking it with CAM-6899. We should be able to work on this soon.
  Jeff
Message 9 of 10
Hey thanks Jeff
Message 10 of 10
Hi Jeff is there a way for us to track CAM-6899? via a web link or something
Paul
