Rectangular Hole
Rectangular Hole
leoE4H8W
Message 1 of 9
Rectangular Hole
leoE4H8W
How can I cut this hole? It goes through the product.Screenshot 2024-07-04 150242.png
Replies (8)
Message 2 of 9
a.laasW8M6T
Hi I would drill the ends out then ramp down with 2d contour and an endmill.
Looking at that part you would need a longer than standard endmill, it will also depend on the material.
Best to use a relieved shank cutter like
Andrew Laas
Senior Machinist, Scott Automation
Message 3 of 9
nubrandao
I would make a drill or two ,
Then countour 2d
Message 4 of 9
leoE4H8W
This is the model, It doesn't cut the hole. I did it before but can't remember how I did it.Screenshot 2024-07-04 161316.png
Message 5 of 9
a.laasW8M6T
Hi
I cant really tell much about what's going on from just a picture. the Fusion File would be more helpful
You probably just need to select the contour you want to machine and turn on ramping in the Linking tab
Andrew Laas
Message 6 of 9
programming2C78B
Is this the 3rd time your posting the same issue? I answered you in the last one. Your depths are too shallow to include the feature in your toolpath.
Please click "Accept Solution" if what I wrote solved your issue!
Message 7 of 9
leoE4H8W
Here's the file
Message 8 of 9
leoE4H8W
Tell which depths are too shallow, please.
Message 9 of 9
leoE4H8W
Finally got it right using 3D contour. Thanks for your help.
