How to add tool break control cycle
nubrandao
Message 1 of 16
nubrandao
hi, i found tool break control line in post processor, but hás no command,  how to make it Write the cycle tool break control?
Im using post processor Heideiain.
TCH PROBE 584 TOOL SETTING L,R ~
Q350=+2 ;MEASURING TYPE ~
Q351=+0 ;APPLICATION ~
Q352=+0 ;CUTTING EDGE CONTROL ~
Q355=-1 ;MEASURING POSITION ~
Q361=+2 ;NUMBER OF MEASURINGS ~
Q362=+0.002 ;SCATTER TOLERANCE ~
Q359=+0 ;ADD. LENGTH CORRECT. ~
Q360=+0 ;ADD. RADIUS CORRECT.
Replies (15)
Message 2 of 16
a.laasW8M6T
Hi
You can add that cycle to the COMMAND_BREAK_CONTROL area
BUT, you must also add some code to determine what to do if the tool is broken.
Do you have the information from the Blum(or DMG) manual for TCH Probe CYCLE 584 and how it works?
It must set a Q value to 1 if the tool is broken, or something similar?
do the machine axes need to be homed before calling the cycle?
including A and C rotary?
Andrew Laas
Senior Machinist, Scott Automation
Message 3 of 16
a.laasW8M6T
Do you have break control implemented in your Powermill posts?
If so you should be able to duplicate the format that the code is output from Powermill into Fusion
Andrew Laas
Message 4 of 16
nubrandao
We never used on company, i found in Fusion NC manual command to check Control break check
I Saw in our machines to break cycle
Then i tried in Fusion, NC tool break, then i Saw that nothing happens
Then in post processor, i Saw empty in tool break command
Só i have no idea what to Write in post processor
I just machine to stop M30 if tool cycle gets error
I Saw something like FN q199 = 0
Go to label 25
m30
Message 5 of 16
nubrandao
In our case, its could BE very helpfull
In our DMG Evo 80
 We 4 tablet fixture, with robot to Change manual
Só the operator can input. 4 diferent fixtures
We had a lot of problems, some Times, a Rough carbide tool is used in the Four fixture,
We had a situation that broken in the first tool Path, all the tools were suposed to go there, broken, more then 10 tools at once.
The we started working in shift, so the operator could check  tools
But if we could use break tool Control, could BE a game changer and all the DMG operator could do normal shift again.
Message 6 of 16
a.laasW8M6T
I can probably create something that will work but you will need to test and adjust yourself.
I can look at it over the weekend
Andrew Laas
Message 7 of 16
nubrandao
Thanks you very much
Message 8 of 16
nubrandao
I Will print a photo tomorrow of our tool break cycle
Our laser is the same place of tool changer...
Basically, at tool Change, we need to check it before put the tool in the magazine. Since they are in the same place. No worry about position Axis.
All i need is to input a cycle "tool break control"
If FN Q199 = 1
Go to Lbl 25
Lb25 M30
Message 9 of 16
nubrandao
  • I found this, could help
FN 11: IF +Q199 GT 0 GOTO LBL 25
(At the end)
LBL 25
END PGM 1234 INCH
Message 10 of 16
a.laasW8M6T
Hi
See attached post
Video for explanation:
(view in My Videos)
Andrew Laas
Message 11 of 16
nubrandao
I Will try it. Thanks you very much for your effort
Message 12 of 16
nubrandao
One question, in our post processor, we had m30 removed because its stops allways at the end of NC program,
for example, i usually create an NC for rough strategys, other NC for finish.
so the operator some, creates a NC program that will call NC-rough + NC-finish
with M30 by default, the machines never starts the second NC because it stopped with, so in this line, i removed M30
  //writeBlock(mFormat.format(30)); // stop program, spindle stop, coolant off
  writeBlock("LBL 0");
but i was thinking, will the machine read M30  in label 25 if the tool is ok? if so, it will stop the machine
should i change the label 25 (m30) for m5? it only pause the machine and spindle right?
ONE
Message 13 of 16
nubrandao
is this valid?
the result
i think this way that if tool is broken, it will jump at the end program right?
i noticed if i manual run tool break cycle, the tool that is broken, becomes locked in the table and i cant run until i unlock it.
maybe, the best way to use this post processor, is to put all toolpaths inside, so it always read M30 at the end, what do you think?
Message 14 of 16
a.laasW8M6T
Yes, if you change it like that it will jump to the end and then return to the calling Program
If you want it to stop the program and not continue, then M5 won't work, it will just stop spindle.
To stop the program you would use M0.
But i think just having it jump to LBL 25 just before the end of program should work fine
I just put all my program in the one file but the sort of work I do is very different than yours, I am the programmer/machinist/operator of just the one machine, so do everything myself.
Andrew Laas
Message 15 of 16
nubrandao
Yes you right
Message 16 of 16
marcelVNUJC
Tank you very much for your explanation.
