"Circular" toolpath doesn't accept new Default
programming2C78B
Advisor Advisor
programming2C78B
With multiple depth, the toolpath keeps resetting the default to "tool_stepdown" which gives weird numbers, like .03934___ (a mm) for a 3/8 endmill. I've set it to be "tool_fluteLength*0.88" at least 3 times, with saving the file, re-starting fusion, power cycling the machine, etc. Everytime I go use Circular, it once again has been set back to _stepdown.
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
Any chance you've got a tool data preset that's overriding it on the "Use Stepdown" option of the preset?
Seth Madore
seth.madore
A quick test on my end showed it to be working as expected 🤔
Seth Madore
programming2C78B
apparently so! Not sure who or where that was enabled that.
