Where do I edit a post processor file?
ferdinand.krall88G99
All I'm trying to do is change the last few lines of NC-code at the end of the program in the "haas next generation.cps" post but I can't find how/where to do the edit. It should be just a plain swap of text, no logic or variables.
Currently it looks like this:
M5
G28 G91 Z0.
G90
G53 G0 X0. Y0.
M30
I want to change it to this format:
M5
G28 G91 Z0.
G28 G91 Y0.
X-150.
G90
M30
programming2C78B
you open the CPS in any text editor and make the adjustments as needed. Save it as a COPY with the same file type.
Please click "Accept Solution" if what I wrote solved your issue!
Well, it's not the first CAM software where I'm editing the post processor
but I can't find the text in the .cps file.
Using Find/Replace and searching for G28, there are ZERO search results!
How do I change this
M5
G28 G91 Z0.
G90
G53 G0 X0. Y0.
M30
to this?
M5
G28 G91 Z0.
G28 G91 Y0.
X-150.
G90
M30
F.
AdamKunzo
"G28 G91 Z0." is not text string in the post. There is a function "writeRetract (Z/X/Y)" that take cares of retracts.
I attached post processor that outputs home position as per your requirement.
You can compare this file with yours to see the modifications I made.
If my response answers your question, please use Accept Solution button.
So then how did you edit the "writeRetract (Z/X/Y)" function to get the result I'm looking for?
matty.fuller
Do as instructed and compare the file with your unmodified version. In Visual Studio Code you can hit Ctrl+Shift+P and then search for "Compare Active File With..." to automatically highlight differences.
