Problem with RAMP leaving material at bottom of pocket.
jda70az
jda70az
Hi.
Ran into a problem where using  Ramp into material to make the start of a pocket
leaves material in the center. Picture & fusion file included if you are interested in taking a look?
Why would this happen? Is the feed rate too low or something.
The CNC machine is a Lead 1010 (Open Builds)
Spindle speed in 17000rpm
using a 1/4" 2 flute spiral up cut bit
cutting feed rate 100 in/min
Ramp feed rate  50in/min
Plunge feed rate 30in/min
Step down .25 in
Step over 0.05 in
seth.madore
I don't think this is a Fusion issue, but more likely a machine and tool clamping issue. What is your machine and tool collet setup?
Seth Madore
jda70az
Hey...
Open Builds Lead 1010 using a Makita  Router RT0701C 1-1/4 HP
I'm assuming it uses a proprietary design. Not an ER collet
I was told it was a backlash issue but it is still doing it after tightening
the Anti backlash Nut on the Z AXIS.
Also  the wood Stock is screwed to the spoilboard.
frederic_jannot
Community Visitor
Community Visitor
Hi, have you found a solution? I've the same issue on all my machining.
seth.madore
@frederic_jannot could you share a file that is giving you this issue?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply
Seth Madore
