Post Processor for Fanuc OM
Message 1 of 9
Hi everybody , i'm using an old CNC machine since 1989 with fanuc OM controller. I have a trouble with post processor for olds machine of my shop , it took me a lot of time to edit CNC program by replace or edit unnessary g  code and m code , so i'm very tired. I watched video tutorial to edit post but it's complicated to understand it . Someone can explain for me construction of post Fusion 360 or have a sample post processor for Fanuc OM? I'm really need it.
Thanks for read my post , my english not good so please help me.
Replies (8)
Message 2 of 9
MoshiurRashid
Hello @Anonymous
Thanks for posting. We have a manufacture forum which is exactly dedicated to CNC and CAM related topics. @seth.madore will help you by moving the post there.
Thanks again.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 3 of 9
seth.madore
@Anonymous  do you have some programs that are adjusted to suit what you DO need? The changes aren't that difficult to do, for the most part, once you have a grasp on how things work.
If you could get a concise and clear list of what's not working and what change you need to make, we can start looking at the post and make suggestions for modifications
Seth Madore
Message 4 of 9
Thanks for your help , a have a code adjusted and it look like g code of mastercam , i will post here and can you explain where can i edit the post processor?
I want to edit start of path like :
O2006
G21
(T2 D=10. CR=0. - ZMIN=-8. - FLAT END MILL)
G90 G0 G17 G49 G40 G80
(2D ADAPTIVE1)
T4 M06
G90 G00 G54 X-10.669 Y-4.126 S6000 M3
G43 Z15. H04
End of path
M09
M05
M01
G91 G28 Z0.
End of program
M09
M05
G91 G28 Z0.
G28 X0. Y0.
M30
Message 5 of 9
Thanks you , Help me 😞
Message 6 of 9
randyT9V9C
I run a 1990's vintage 15M (0M). The generic Fanuc post processor worked for most basic things. Canned cycles will likely need to be added/changed to match your machine. For example, I had to change rigid tapping from G84 to G84.2/G84.3. Here is a link to my post processor: http://home.lewiscounty.com/~forhire/posts/fanuc15m.cps
Message 7 of 9
seth.madore
Do you actually need the "Start of Path" and "End of Path" and "End of Program"?
Seth Madore
Message 8 of 9
Yes , i need edit the "Start of Path" and "End of Path" and "End of Program"  , because my cnc machines only understand g code look like that to run program
Message 9 of 9
Thank for your reply , i'll try it for my CNC machines
