Feedrates in setup sheet
wildemfg
wildemfg
I print out the Fusion360 setup sheet with every program I post and would like to add cutting, lead-in/out, ramping, and plunge feedrates to the setup sheet.
Stock, it only posts max feedrate, and in say a milling operation, the plunge might be 300ipm, but the cutting feedrate might be 12ipm. making that max feedrate kind of useless.
jameshorne0503
You should be able to edit the setupsheet post processor to include these feeds. I can't remember what the codes are for this though. A little while ago there was a forum post about adding comments about different operations but i believe they used "onMovement()" which isn't strictly relevant to you but could be used as a work around somehow.
Info on these commands can be found in the post processor training guide: https://cam.autodesk.com/posts/posts/guides/Post%20Processor%20Training%20Guide.pdf
Hope this helps!
