Post processor folder invalid
friesendrywall
Message 1 of 16
friesendrywall
I get this every time I post process, apparently it doesn't remember that I said YES the previous time.
Replies (15)
Message 2 of 16
jeff.walters
This happens after an update. The hexadecimal folder name changes so the old path is no longer correct.
Jeff Walters
Senior Support Engineer, CAM
Message 3 of 16
landslide1
Is there any way to stop this happening?
It is so annoying having to reset and reconfigure my posting options every time I use the program.
Message 4 of 16
Steinwerks
Copy your preferred post into your Cloud posts and use it from there instead.
If you're not sure how to do this, here's an instructional: https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
And you can download the post (and many that are not included in the standard install folder) from here if you can't manage to locate it in the default directory: http://cam.autodesk.com/posts/
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 5 of 16
jeff.pek
FYI, we'll have a fix for this in an upcoming Fusion update. After that update, you'll probably see that message one more time. After that, we'll store the folder path differently, so that it automatically follows the new location of the "generic" post folder.
Jeff
Message 6 of 16
jrichels20
Hello, I think I see this identical issue. The attached JPG shows the resulting dialog boxes. After an update, when selecting Post Process, the post directory is set to a non-existent location. Selecting either Yes or No in the box to reset to a default location sets a default location that is not mine. Fix is to manually replace the output folder with my desired output folder. This issue has nothing to do with a particular project. Thanks. Jeff
Message 7 of 16
jrichels20
delete
Message 8 of 16
Almost 2019, and this is still happening....why?
Message 9 of 16
jeff.pek
I'll take a look at  this; I though this was fixed a long time ago.
  Jeff
Message 10 of 16
jeff.pek
FYI, looks like this was broken again earlier this year to fix another problem.
Will need to reapply the change (while of course avoiding the other problem).
Thanks for pointing this out. CAM-12273.
Jeff
Message 11 of 16
So I had to reload Fusion 360 because a few files were no longer running correctly. After doing so Autodesk seems to be running fine but once I try to Post Process an item I created it is giving me that message with the choice of Yes and No. I choose No, so how do I find the correct file I was running before so I can use Mack 3 to cut this out?
Message 12 of 16
seth.madore
Select "Yes" so Fusion will locate the correct post processor.
This is an excellent example as to why you should always download and secure your own post processor far away from the generic directory that gets overwritten every time an update rolls out.
Seth Madore
Message 13 of 16
dustymiller64
I am suffering the same issue of the post processor directory "not found" after every update. Finally got fed up searching for the folder manually every time and have come looking for a solution. I don't get a "yes or no" dialog box, the post processor list is just empty.
You mention using a cloud location for the post processor, are you saying that local post processor folders aren't recommended?
Regards Simon
Message 14 of 16
seth.madore
I wouldn't say that I don't recommend local folders, however, I would say that I prefer cloud folders, as I find myself moving between several computers over the course of the week.
Are you not finding the generic built-in posts?
Seth Madore
Message 15 of 16
dustymiller64
I can always find the post processor folder by browsing.
Do the standard local folders for the post processors work flawlessly?
Is there a problem with the location of the standard folder being lost during an update?
I am trying to work out if this is a Fusion issue or an issue specific to my setup.
By the way I run Fusion on two PCs, one at work and one at home, they both show this problem.
Regards Simon
Message 16 of 16
dustymiller64
Just updated to 2.0.7824 and the post processor list is now pointing at the wrong hex folder!
