Post processor fails when trying to use Pattern option in Cam with a tombstone
gwshaffer01
gwshaffer01
Im using the Tormach post processor to run 1100 series 3  with a tombstone attached to the 4th axis. I can pattern all 4 parts fine (1 on each side) in cam but the Tormach post immediately errors out.
Any help is greatly appreciated! thanks!
johnswetz1982
Can you File>Export>*.f3D and attach to the thread. What post processor are you using?
gwshaffer01
Im using the latest Tormach post processor. Ive uploaded a simple facing operation
johnswetz1982
I disabled the tool orientation you had in the op because it is not needed in this case. I think the issue was with your work offset. I changed the origin to be model origin and picked the X axis by choosing the Y axis under the origin in the component browser. It posts after that. see attached.
gwshaffer01
Thank You! Needless to say im new and the parts ill be running are much more difficult than this but i understand a little better now. I may still come back to this thread but I really appreciate your help.
