Post processing permanent changes
Message 1 of 10
So my G69 issue brought to light the fact that I can tweak the post program.  Every post for me requires me to change a few things.  The biggest is when to turn off the coolant and when to turn it on.  I do not have a full enclosure so I need to turn the coolant on/off much lower.  I do it at Z 2. and add a 1 second dwell.  Also I need to turn off the coolant at Z 0.6 right after the section ends.  This is a real bummer for ops that have say 5-6 tools and changes involved.  Can I make these changes to always be added in my post processing?  Also can I remove the addition of G54 after every tool change?  I don't ever use G54 since it is dedicated to setting my tool lengths.
Thanks in advance.
Cheers,
Drew
Replies (9)
Message 2 of 10
LibertyMachine
Do you use G55 instead?
Attach a simple text g-code file showing exactly where you want what (in RED FONT for clarity) and those edits can be done fairly easy
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 10
LibertyMachine
I had some time while I ate my breakfast, so I made a few edits to a stock Haas post.
G69 removed (you had that already)
M8 moved to after the G43 line with a dwell thereafter. Not certain how long a dwell was needed, so I will show you how to change it later if needed
Work offset will now be incremented one spot up. If you leave it set to "1" in the setup, it will post out G55. If you set it to "2", it will post out G56.
Seth Madore
Message 4 of 10
Wow thanks.  I use all kinds of settings.  G55-57 as well as G110-G129  Often I have all three vises with a different op in each one going.  So essentially I only want it in the opening of the program so I only need to change it once and not after every tool change.
I was looking for a dwell of just 1 second to give the coolant a chance to get going.
I also need the M09 moved to just before M5 before the tool change is going to happen.  Here is a quick one that I made the edits on the dwell time, M9 and rmoved the extra G55
O01001
(Seat Collar)
(T1 D=0.25 CR=0. - ZMIN=-1.1 - flat end mill)
(T4 D=0.25 CR=0. TAPER=45deg - ZMIN=-0.0945 - chamfer mill)
N10 G90 G94 G17
N15 G20
N20 G53 G0 Z0.
(O.D. Countor)
N30 T1 M6
N35 S4000 M3
N40 G55
N55 G0 X-0.1716 Y-0.8146
N60 G43 Z0.6 H1
N65 M8
N70 G4 P1.
N75 G0 Z0.2894
N80 G1 Z-0.225 F15.
N85 X-0.1713 Y-0.8145 Z-0.2289
N90 X-0.1704 Z-0.2327
N95 X-0.1689 Y-0.8143 Z-0.2363
N100 X-0.1669 Y-0.8142 Z-0.2397
N105 X-0.1643 Y-0.814 Z-0.2427
N110 X-0.1614 Y-0.8137 Z-0.2452
N115 X-0.158 Y-0.8134 Z-0.2473
N120 X-0.1544 Y-0.8131 Z-0.2488
N125 X-0.1506 Y-0.8128 Z-0.2497
N130 X-0.1467 Y-0.8125 Z-0.25
N135 X-0.1218 Y-0.8104
N140 G3 X-0.0989 Y-0.7835 I-0.0021 J0.0249
N145 G2 X-0.0992 Y-0.78 I0.1495 J0.0124 F25.
N150 G1 X-0.0996 Y-0.7732
N155 G2 X-0.0998 Y-0.7672 I0.1497 J0.0089
N160 G1 X-0.1 Y-0.7605
N165 G2 Y-0.7575 I0.15 J0.003
N170 G1 Y-0.75
N175 G2 X0.675 Y0.025 I0.775 J0.
N180 G1 X1.0701
N185 G2 X2.1 Y-0.9933 I0. J-1.03
N190 Y-0.995 I-0.15 J-0.0017
N195 X1.07 Y-2.025 I-1.03 J0.
N200 G1 X0.675
N205 G2 X-0.1 Y-1.25 I0. J0.775
N210 G1 Y-1.2425
N215 G2 Y-1.2395 I0.15 J0.
N220 G1 X-0.0998 Y-1.2328
N225 G2 X-0.0996 Y-1.2268 I0.15 J-0.003
N230 G1 X-0.0992 Y-1.22
N235 G2 X-0.0987 Y-1.2141 I0.1497 J-0.0089
N240 G1 X-0.098 Y-1.2071
N245 G2 X-0.0973 Y-1.2013 I0.1493 J-0.0148
N250 G1 X-0.0964 Y-1.1943
N255 G2 X-0.0954 Y-1.1883 I0.1486 J-0.0207
N260 G1 X-0.0941 Y-1.1813
N265 G2 X-0.0929 Y-1.1753 I0.1476 J-0.0266
N270 G1 X-0.0914 Y-1.1683
N275 G2 X-0.0899 Y-1.1623 I0.1464 J-0.0326
N280 G1 X-0.088 Y-1.1552
N285 G2 X-0.0863 Y-1.1491 I0.145 J-0.0386
N290 G1 X-0.0841 Y-1.1421
N295 G2 X-0.082 Y-1.1359 I0.1432 J-0.0446
N300 G1 X-0.0795 Y-1.1289
N305 G2 X-0.0771 Y-1.1228 I0.1411 J-0.0508
N310 G1 X-0.0743 Y-1.1159
N315 G2 X-0.0717 Y-1.11 I0.1388 J-0.0569
N320 G1 X-0.0686 Y-1.1032
N325 G2 X-0.0658 Y-1.0975 I0.1362 J-0.0628
N330 G1 X-0.0624 Y-1.0908
N335 G2 X-0.0593 Y-1.0852 I0.1334 J-0.0685
N340 G1 X-0.0556 Y-1.0786
N345 G2 X-0.0523 Y-1.0731 I0.1304 J-0.0742
N350 G1 X-0.0483 Y-1.0667
N355 G2 X-0.0448 Y-1.0613 I0.1271 J-0.0796
N360 G1 X-0.0405 Y-1.0551
N365 G2 X-0.0367 Y-1.0498 I0.1236 J-0.085
N370 G1 X-0.0321 Y-1.0438
N375 G2 X-0.028 Y-1.0386 I0.1198 J-0.0903
N380 G1 X-0.0232 Y-1.0327
N385 G2 X-0.0188 Y-1.0276 I0.1157 J-0.0955
N390 G1 X-0.0135 Y-1.0218
N395 G2 X-0.0089 Y-1.0169 I0.1113 J-0.1006
N400 G1 X-0.0032 Y-1.0111
N405 G2 X0.0018 Y-1.0064 I0.1066 J-0.1055
N410 G1 X0.0079 Y-1.0007
N415 G2 X0.0087 Y-1. I0.1016 J-0.1103
N420 X0.0079 Y-0.9993 I0.1009 J0.111
N425 G1 X0.0018 Y-0.9936
N430 G2 X-0.0032 Y-0.9889 I0.1016 J0.1103
N435 G1 X-0.0089 Y-0.9831
N440 G2 X-0.0135 Y-0.9782 I0.1066 J0.1055
N445 G1 X-0.0188 Y-0.9724
N450 G2 X-0.0232 Y-0.9673 I0.1113 J0.1006
N455 G1 X-0.028 Y-0.9614
N460 G2 X-0.0321 Y-0.9562 I0.1157 J0.0955
N465 G1 X-0.0367 Y-0.9502
N470 G2 X-0.0405 Y-0.9449 I0.1198 J0.0903
N475 G1 X-0.0448 Y-0.9387
N480 G2 X-0.0483 Y-0.9333 I0.1236 J0.085
N485 G1 X-0.0523 Y-0.9269
N490 G2 X-0.0556 Y-0.9214 I0.1271 J0.0796
N495 G1 X-0.0593 Y-0.9148
N500 G2 X-0.0624 Y-0.9092 I0.1304 J0.0742
N505 G1 X-0.0658 Y-0.9025
N510 G2 X-0.0686 Y-0.8968 I0.1334 J0.0685
N515 G1 X-0.0717 Y-0.89
N520 G2 X-0.0743 Y-0.8841 I0.1362 J0.0628
N525 G1 X-0.0771 Y-0.8772
N530 G2 X-0.0795 Y-0.8711 I0.1388 J0.0569
N535 G1 X-0.082 Y-0.8641
N540 G2 X-0.0841 Y-0.8579 I0.1411 J0.0508
N545 G1 X-0.0863 Y-0.8509
N550 G2 X-0.088 Y-0.8448 I0.1432 J0.0447
N555 G1 X-0.0899 Y-0.8377
N560 G2 X-0.0914 Y-0.8317 I0.145 J0.0386
N565 G1 X-0.0929 Y-0.8247
N570 G2 X-0.0941 Y-0.8187 I0.1464 J0.0326
N575 G1 X-0.0954 Y-0.8117
N580 G2 X-0.0964 Y-0.8057 I0.1476 J0.0266
N585 G1 X-0.0973 Y-0.7987
N590 G2 X-0.098 Y-0.7929 I0.1486 J0.0207
N595 G1 X-0.0987 Y-0.7859
N600 G2 X-0.0989 Y-0.7835 I0.1493 J0.0148
N605 G3 X-0.1259 Y-0.7606 I-0.0249 J-0.0021 F30.
N610 G1 X-0.1508 Y-0.7627
N615 X-0.1547 Y-0.763 Z-0.2497
N620 X-0.1585 Y-0.7633 Z-0.2488
N625 X-0.1621 Y-0.7636 Z-0.2473
N630 X-0.1655 Y-0.7639 Z-0.2452
N635 X-0.1685 Y-0.7641 Z-0.2427
N640 X-0.171 Y-0.7643 Z-0.2397
N645 X-0.173 Y-0.7645 Z-0.2363
N650 X-0.1745 Y-0.7646 Z-0.2327
N655 X-0.1754 Y-0.7647 Z-0.2289
N660 X-0.1758 Z-0.225
N665 G0 Z0.2
N670 G1 X-0.1716 Y-0.8146 F150.
N675 Z0.0394 F15.
N680 Z-0.475
N685 X-0.1713 Y-0.8145 Z-0.4789
N690 X-0.1704 Z-0.4827
N695 X-0.1689 Y-0.8143 Z-0.4863
N700 X-0.1669 Y-0.8142 Z-0.4897
N705 X-0.1643 Y-0.814 Z-0.4927
N710 X-0.1614 Y-0.8137 Z-0.4952
N715 X-0.158 Y-0.8134 Z-0.4973
N720 X-0.1544 Y-0.8131 Z-0.4988
N725 X-0.1506 Y-0.8128 Z-0.4997
N730 X-0.1467 Y-0.8125 Z-0.5
N735 X-0.1218 Y-0.8104
N740 G3 X-0.0989 Y-0.7835 I-0.0021 J0.0249
N745 G2 X-0.0992 Y-0.78 I0.1495 J0.0124 F25.
N750 G1 X-0.0996 Y-0.7732
N755 G2 X-0.0998 Y-0.7672 I0.1497 J0.0089
N760 G1 X-0.1 Y-0.7605
N765 G2 Y-0.7575 I0.15 J0.003
N770 G1 Y-0.75
N775 G2 X0.675 Y0.025 I0.775 J0.
N780 G1 X1.0701
N785 G2 X2.1 Y-0.9933 I0. J-1.03
N790 Y-0.995 I-0.15 J-0.0017
N795 X1.07 Y-2.025 I-1.03 J0.
N800 G1 X0.675
N805 G2 X-0.1 Y-1.25 I0. J0.775
N810 G1 Y-1.2425
N815 G2 Y-1.2395 I0.15 J0.
N820 G1 X-0.0998 Y-1.2328
N825 G2 X-0.0996 Y-1.2268 I0.15 J-0.003
N830 G1 X-0.0992 Y-1.22
N835 G2 X-0.0987 Y-1.2141 I0.1497 J-0.0089
N840 G1 X-0.098 Y-1.2071
N845 G2 X-0.0973 Y-1.2013 I0.1493 J-0.0148
N850 G1 X-0.0964 Y-1.1943
N855 G2 X-0.0954 Y-1.1883 I0.1486 J-0.0207
N860 G1 X-0.0941 Y-1.1813
N865 G2 X-0.0929 Y-1.1753 I0.1476 J-0.0266
N870 G1 X-0.0914 Y-1.1683
N875 G2 X-0.0899 Y-1.1623 I0.1464 J-0.0326
N880 G1 X-0.088 Y-1.1552
N885 G2 X-0.0863 Y-1.1491 I0.145 J-0.0386
N890 G1 X-0.0841 Y-1.1421
N895 G2 X-0.082 Y-1.1359 I0.1432 J-0.0446
N900 G1 X-0.0795 Y-1.1289
N905 G2 X-0.0771 Y-1.1228 I0.1411 J-0.0508
N910 G1 X-0.0743 Y-1.1159
N915 G2 X-0.0717 Y-1.11 I0.1388 J-0.0569
N920 G1 X-0.0686 Y-1.1032
N925 G2 X-0.0658 Y-1.0975 I0.1362 J-0.0628
N930 G1 X-0.0624 Y-1.0908
N935 G2 X-0.0593 Y-1.0852 I0.1334 J-0.0685
N940 G1 X-0.0556 Y-1.0786
N945 G2 X-0.0523 Y-1.0731 I0.1304 J-0.0742
N950 G1 X-0.0483 Y-1.0667
N955 G2 X-0.0448 Y-1.0613 I0.1271 J-0.0796
N960 G1 X-0.0405 Y-1.0551
N965 G2 X-0.0367 Y-1.0498 I0.1236 J-0.085
N970 G1 X-0.0321 Y-1.0438
N975 G2 X-0.028 Y-1.0386 I0.1198 J-0.0903
N980 G1 X-0.0232 Y-1.0327
N985 G2 X-0.0188 Y-1.0276 I0.1157 J-0.0955
N990 G1 X-0.0135 Y-1.0218
N995 G2 X-0.0089 Y-1.0169 I0.1113 J-0.1006
N1000 G1 X-0.0032 Y-1.0111
N1005 G2 X0.0018 Y-1.0064 I0.1066 J-0.1055
N1010 G1 X0.0079 Y-1.0007
N1015 G2 X0.0087 Y-1. I0.1016 J-0.1103
N1020 X0.0079 Y-0.9993 I0.1009 J0.111
N1025 G1 X0.0018 Y-0.9936
N1030 G2 X-0.0032 Y-0.9889 I0.1016 J0.1103
N1035 G1 X-0.0089 Y-0.9831
N1040 G2 X-0.0135 Y-0.9782 I0.1066 J0.1055
N1045 G1 X-0.0188 Y-0.9724
N1050 G2 X-0.0232 Y-0.9673 I0.1113 J0.1006
N1055 G1 X-0.028 Y-0.9614
N1060 G2 X-0.0321 Y-0.9562 I0.1157 J0.0955
N1065 G1 X-0.0367 Y-0.9502
N1070 G2 X-0.0405 Y-0.9449 I0.1198 J0.0903
N1075 G1 X-0.0448 Y-0.9387
N1080 G2 X-0.0483 Y-0.9333 I0.1236 J0.085
N1085 G1 X-0.0523 Y-0.9269
N1090 G2 X-0.0556 Y-0.9214 I0.1271 J0.0796
N1095 G1 X-0.0593 Y-0.9148
N1100 G2 X-0.0624 Y-0.9092 I0.1304 J0.0742
N1105 G1 X-0.0658 Y-0.9025
N1110 G2 X-0.0686 Y-0.8968 I0.1334 J0.0685
N1115 G1 X-0.0717 Y-0.89
N1120 G2 X-0.0743 Y-0.8841 I0.1362 J0.0628
N1125 G1 X-0.0771 Y-0.8772
N1130 G2 X-0.0795 Y-0.8711 I0.1388 J0.0569
N1135 G1 X-0.082 Y-0.8641
N1140 G2 X-0.0841 Y-0.8579 I0.1411 J0.0508
N1145 G1 X-0.0863 Y-0.8509
N1150 G2 X-0.088 Y-0.8448 I0.1432 J0.0447
N1155 G1 X-0.0899 Y-0.8377
N1160 G2 X-0.0914 Y-0.8317 I0.145 J0.0386
N1165 G1 X-0.0929 Y-0.8247
N1170 G2 X-0.0941 Y-0.8187 I0.1464 J0.0326
N1175 G1 X-0.0954 Y-0.8117
N1180 G2 X-0.0964 Y-0.8057 I0.1476 J0.0266
N1185 G1 X-0.0973 Y-0.7987
N1190 G2 X-0.098 Y-0.7929 I0.1486 J0.0207
N1195 G1 X-0.0987 Y-0.7859
N1200 G2 X-0.0989 Y-0.7835 I0.1493 J0.0148
N1205 G3 X-0.1259 Y-0.7606 I-0.0249 J-0.0021 F30.
N1210 G1 X-0.1508 Y-0.7627
N1215 X-0.1547 Y-0.763 Z-0.4997
N1220 X-0.1585 Y-0.7633 Z-0.4988
N1225 X-0.1621 Y-0.7636 Z-0.4973
N1230 X-0.1655 Y-0.7639 Z-0.4952
N1235 X-0.1685 Y-0.7641 Z-0.4927
N1240 X-0.171 Y-0.7643 Z-0.4897
N1245 X-0.173 Y-0.7645 Z-0.4863
N1250 X-0.1745 Y-0.7646 Z-0.4827
N1255 X-0.1754 Y-0.7647 Z-0.4789
N1260 X-0.1758 Z-0.475
N1265 G0 Z0.2
N1270 G1 X-0.1716 Y-0.8146 F150.
N1275 Z-0.2106 F15.
N1280 Z-0.725
N1285 X-0.1713 Y-0.8145 Z-0.7289
N1290 X-0.1704 Z-0.7327
N1295 X-0.1689 Y-0.8143 Z-0.7363
N1300 X-0.1669 Y-0.8142 Z-0.7397
N1305 X-0.1643 Y-0.814 Z-0.7427
N1310 X-0.1614 Y-0.8137 Z-0.7452
N1315 X-0.158 Y-0.8134 Z-0.7473
N1320 X-0.1544 Y-0.8131 Z-0.7488
N1325 X-0.1506 Y-0.8128 Z-0.7497
N1330 X-0.1467 Y-0.8125 Z-0.75
N1335 X-0.1218 Y-0.8104
N1340 G3 X-0.0989 Y-0.7835 I-0.0021 J0.0249
N1345 G2 X-0.0992 Y-0.78 I0.1495 J0.0124 F25.
N1350 G1 X-0.0996 Y-0.7732
N1355 G2 X-0.0998 Y-0.7672 I0.1497 J0.0089
N1360 G1 X-0.1 Y-0.7605
N1365 G2 Y-0.7575 I0.15 J0.003
N1370 G1 Y-0.75
N1375 G2 X0.675 Y0.025 I0.775 J0.
N1380 G1 X1.0701
N1385 G2 X2.1 Y-0.9933 I0. J-1.03
N1390 Y-0.995 I-0.15 J-0.0017
N1395 X1.07 Y-2.025 I-1.03 J0.
N1400 G1 X0.675
N1405 G2 X-0.1 Y-1.25 I0. J0.775
N1410 G1 Y-1.2425
N1415 G2 Y-1.2395 I0.15 J0.
N1420 G1 X-0.0998 Y-1.2328
N1425 G2 X-0.0996 Y-1.2268 I0.15 J-0.003
N1430 G1 X-0.0992 Y-1.22
N1435 G2 X-0.0987 Y-1.2141 I0.1497 J-0.0089
N1440 G1 X-0.098 Y-1.2071
N1445 G2 X-0.0973 Y-1.2013 I0.1493 J-0.0148
N1450 G1 X-0.0964 Y-1.1943
N1455 G2 X-0.0954 Y-1.1883 I0.1486 J-0.0207
N1460 G1 X-0.0941 Y-1.1813
N1465 G2 X-0.0929 Y-1.1753 I0.1476 J-0.0266
N1470 G1 X-0.0914 Y-1.1683
N1475 G2 X-0.0899 Y-1.1623 I0.1464 J-0.0326
N1480 G1 X-0.088 Y-1.1552
N1485 G2 X-0.0863 Y-1.1491 I0.145 J-0.0386
N1490 G1 X-0.0841 Y-1.1421
N1495 G2 X-0.082 Y-1.1359 I0.1432 J-0.0446
N1500 G1 X-0.0795 Y-1.1289
N1505 G2 X-0.0771 Y-1.1228 I0.1411 J-0.0508
N1510 G1 X-0.0743 Y-1.1159
N1515 G2 X-0.0717 Y-1.11 I0.1388 J-0.0569
N1520 G1 X-0.0686 Y-1.1032
N1525 G2 X-0.0658 Y-1.0975 I0.1362 J-0.0628
N1530 G1 X-0.0624 Y-1.0908
N1535 G2 X-0.0593 Y-1.0852 I0.1334 J-0.0685
N1540 G1 X-0.0556 Y-1.0786
N1545 G2 X-0.0523 Y-1.0731 I0.1304 J-0.0742
N1550 G1 X-0.0483 Y-1.0667
N1555 G2 X-0.0448 Y-1.0613 I0.1271 J-0.0796
N1560 G1 X-0.0405 Y-1.0551
N1565 G2 X-0.0367 Y-1.0498 I0.1236 J-0.085
N1570 G1 X-0.0321 Y-1.0438
N1575 G2 X-0.028 Y-1.0386 I0.1198 J-0.0903
N1580 G1 X-0.0232 Y-1.0327
N1585 G2 X-0.0188 Y-1.0276 I0.1157 J-0.0955
N1590 G1 X-0.0135 Y-1.0218
N1595 G2 X-0.0089 Y-1.0169 I0.1113 J-0.1006
N1600 G1 X-0.0032 Y-1.0111
N1605 G2 X0.0018 Y-1.0064 I0.1066 J-0.1055
N1610 G1 X0.0079 Y-1.0007
N1615 G2 X0.0087 Y-1. I0.1016 J-0.1103
N1620 X0.0079 Y-0.9993 I0.1009 J0.111
N1625 G1 X0.0018 Y-0.9936
N1630 G2 X-0.0032 Y-0.9889 I0.1016 J0.1103
N1635 G1 X-0.0089 Y-0.9831
N1640 G2 X-0.0135 Y-0.9782 I0.1066 J0.1055
N1645 G1 X-0.0188 Y-0.9724
N1650 G2 X-0.0232 Y-0.9673 I0.1113 J0.1006
N1655 G1 X-0.028 Y-0.9614
N1660 G2 X-0.0321 Y-0.9562 I0.1157 J0.0955
N1665 G1 X-0.0367 Y-0.9502
N1670 G2 X-0.0405 Y-0.9449 I0.1198 J0.0903
N1675 G1 X-0.0448 Y-0.9387
N1680 G2 X-0.0483 Y-0.9333 I0.1236 J0.085
N1685 G1 X-0.0523 Y-0.9269
N1690 G2 X-0.0556 Y-0.9214 I0.1271 J0.0796
N1695 G1 X-0.0593 Y-0.9148
N1700 G2 X-0.0624 Y-0.9092 I0.1304 J0.0742
N1705 G1 X-0.0658 Y-0.9025
N1710 G2 X-0.0686 Y-0.8968 I0.1334 J0.0685
N1715 G1 X-0.0717 Y-0.89
N1720 G2 X-0.0743 Y-0.8841 I0.1362 J0.0628
N1725 G1 X-0.0771 Y-0.8772
N1730 G2 X-0.0795 Y-0.8711 I0.1388 J0.0569
N1735 G1 X-0.082 Y-0.8641
N1740 G2 X-0.0841 Y-0.8579 I0.1411 J0.0508
N1745 G1 X-0.0863 Y-0.8509
N1750 G2 X-0.088 Y-0.8448 I0.1432 J0.0447
N1755 G1 X-0.0899 Y-0.8377
N1760 G2 X-0.0914 Y-0.8317 I0.145 J0.0386
N1765 G1 X-0.0929 Y-0.8247
N1770 G2 X-0.0941 Y-0.8187 I0.1464 J0.0326
N1775 G1 X-0.0954 Y-0.8117
N1780 G2 X-0.0964 Y-0.8057 I0.1476 J0.0266
N1785 G1 X-0.0973 Y-0.7987
N1790 G2 X-0.098 Y-0.7929 I0.1486 J0.0207
N1795 G1 X-0.0987 Y-0.7859
N1800 G2 X-0.0989 Y-0.7835 I0.1493 J0.0148
N1805 G3 X-0.1259 Y-0.7606 I-0.0249 J-0.0021 F30.
N1810 G1 X-0.1508 Y-0.7627
N1815 X-0.1547 Y-0.763 Z-0.7497
N1820 X-0.1585 Y-0.7633 Z-0.7488
N1825 X-0.1621 Y-0.7636 Z-0.7473
N1830 X-0.1655 Y-0.7639 Z-0.7452
N1835 X-0.1685 Y-0.7641 Z-0.7427
N1840 X-0.171 Y-0.7643 Z-0.7397
N1845 X-0.173 Y-0.7645 Z-0.7363
N1850 X-0.1745 Y-0.7646 Z-0.7327
N1855 X-0.1754 Y-0.7647 Z-0.7289
N1860 X-0.1758 Z-0.725
N1865 G0 Z0.2
N1870 G1 X-0.1716 Y-0.8146 F150.
N1875 Z-0.4606 F15.
N1880 Z-0.975
N1885 X-0.1713 Y-0.8145 Z-0.9789
N1890 X-0.1704 Z-0.9827
N1895 X-0.1689 Y-0.8143 Z-0.9863
N1900 X-0.1669 Y-0.8142 Z-0.9897
N1905 X-0.1643 Y-0.814 Z-0.9927
N1910 X-0.1614 Y-0.8137 Z-0.9952
N1915 X-0.158 Y-0.8134 Z-0.9973
N1920 X-0.1544 Y-0.8131 Z-0.9988
N1925 X-0.1506 Y-0.8128 Z-0.9997
N1930 X-0.1467 Y-0.8125 Z-1.
N1935 X-0.1218 Y-0.8104
N1940 G3 X-0.0989 Y-0.7835 I-0.0021 J0.0249
N1945 G2 X-0.0992 Y-0.78 I0.1495 J0.0124 F25.
N1950 G1 X-0.0996 Y-0.7732
N1955 G2 X-0.0998 Y-0.7672 I0.1497 J0.0089
N1960 G1 X-0.1 Y-0.7605
N1965 G2 Y-0.7575 I0.15 J0.003
N1970 G1 Y-0.75
N1975 G2 X0.675 Y0.025 I0.775 J0.
N1980 G1 X1.0701
N1985 G2 X2.1 Y-0.9933 I0. J-1.03
N1990 Y-0.995 I-0.15 J-0.0017
N1995 X1.07 Y-2.025 I-1.03 J0.
N2000 G1 X0.675
N2005 G2 X-0.1 Y-1.25 I0. J0.775
N2010 G1 Y-1.2425
N2015 G2 Y-1.2395 I0.15 J0.
N2020 G1 X-0.0998 Y-1.2328
N2025 G2 X-0.0996 Y-1.2268 I0.15 J-0.003
N2030 G1 X-0.0992 Y-1.22
N2035 G2 X-0.0987 Y-1.2141 I0.1497 J-0.0089
N2040 G1 X-0.098 Y-1.2071
N2045 G2 X-0.0973 Y-1.2013 I0.1493 J-0.0148
N2050 G1 X-0.0964 Y-1.1943
N2055 G2 X-0.0954 Y-1.1883 I0.1486 J-0.0207
N2060 G1 X-0.0941 Y-1.1813
N2065 G2 X-0.0929 Y-1.1753 I0.1476 J-0.0266
N2070 G1 X-0.0914 Y-1.1683
N2075 G2 X-0.0899 Y-1.1623 I0.1464 J-0.0326
N2080 G1 X-0.088 Y-1.1552
N2085 G2 X-0.0863 Y-1.1491 I0.145 J-0.0386
N2090 G1 X-0.0841 Y-1.1421
N2095 G2 X-0.082 Y-1.1359 I0.1432 J-0.0446
N2100 G1 X-0.0795 Y-1.1289
N2105 G2 X-0.0771 Y-1.1228 I0.1411 J-0.0508
N2110 G1 X-0.0743 Y-1.1159
N2115 G2 X-0.0717 Y-1.11 I0.1388 J-0.0569
N2120 G1 X-0.0686 Y-1.1032
N2125 G2 X-0.0658 Y-1.0975 I0.1362 J-0.0628
N2130 G1 X-0.0624 Y-1.0908
N2135 G2 X-0.0593 Y-1.0852 I0.1334 J-0.0685
N2140 G1 X-0.0556 Y-1.0786
N2145 G2 X-0.0523 Y-1.0731 I0.1304 J-0.0742
N2150 G1 X-0.0483 Y-1.0667
N2155 G2 X-0.0448 Y-1.0613 I0.1271 J-0.0796
N2160 G1 X-0.0405 Y-1.0551
N2165 G2 X-0.0367 Y-1.0498 I0.1236 J-0.085
N2170 G1 X-0.0321 Y-1.0438
N2175 G2 X-0.028 Y-1.0386 I0.1198 J-0.0903
N2180 G1 X-0.0232 Y-1.0327
N2185 G2 X-0.0188 Y-1.0276 I0.1157 J-0.0955
N2190 G1 X-0.0135 Y-1.0218
N2195 G2 X-0.0089 Y-1.0169 I0.1113 J-0.1006
N2200 G1 X-0.0032 Y-1.0111
N2205 G2 X0.0018 Y-1.0064 I0.1066 J-0.1055
N2210 G1 X0.0079 Y-1.0007
N2215 G2 X0.0087 Y-1. I0.1016 J-0.1103
N2220 X0.0079 Y-0.9993 I0.1009 J0.111
N2225 G1 X0.0018 Y-0.9936
N2230 G2 X-0.0032 Y-0.9889 I0.1016 J0.1103
N2235 G1 X-0.0089 Y-0.9831
N2240 G2 X-0.0135 Y-0.9782 I0.1066 J0.1055
N2245 G1 X-0.0188 Y-0.9724
N2250 G2 X-0.0232 Y-0.9673 I0.1113 J0.1006
N2255 G1 X-0.028 Y-0.9614
N2260 G2 X-0.0321 Y-0.9562 I0.1157 J0.0955
N2265 G1 X-0.0367 Y-0.9502
N2270 G2 X-0.0405 Y-0.9449 I0.1198 J0.0903
N2275 G1 X-0.0448 Y-0.9387
N2280 G2 X-0.0483 Y-0.9333 I0.1236 J0.085
N2285 G1 X-0.0523 Y-0.9269
N2290 G2 X-0.0556 Y-0.9214 I0.1271 J0.0796
N2295 G1 X-0.0593 Y-0.9148
N2300 G2 X-0.0624 Y-0.9092 I0.1304 J0.0742
N2305 G1 X-0.0658 Y-0.9025
N2310 G2 X-0.0686 Y-0.8968 I0.1334 J0.0685
N2315 G1 X-0.0717 Y-0.89
N2320 G2 X-0.0743 Y-0.8841 I0.1362 J0.0628
N2325 G1 X-0.0771 Y-0.8772
N2330 G2 X-0.0795 Y-0.8711 I0.1388 J0.0569
N2335 G1 X-0.082 Y-0.8641
N2340 G2 X-0.0841 Y-0.8579 I0.1411 J0.0508
N2345 G1 X-0.0863 Y-0.8509
N2350 G2 X-0.088 Y-0.8448 I0.1432 J0.0447
N2355 G1 X-0.0899 Y-0.8377
N2360 G2 X-0.0914 Y-0.8317 I0.145 J0.0386
N2365 G1 X-0.0929 Y-0.8247
N2370 G2 X-0.0941 Y-0.8187 I0.1464 J0.0326
N2375 G1 X-0.0954 Y-0.8117
N2380 G2 X-0.0964 Y-0.8057 I0.1476 J0.0266
N2385 G1 X-0.0973 Y-0.7987
N2390 G2 X-0.098 Y-0.7929 I0.1486 J0.0207
N2395 G1 X-0.0987 Y-0.7859
N2400 G2 X-0.0989 Y-0.7835 I0.1493 J0.0148
N2405 G3 X-0.1259 Y-0.7606 I-0.0249 J-0.0021 F30.
N2410 G1 X-0.1508 Y-0.7627
N2415 X-0.1547 Y-0.763 Z-0.9997
N2420 X-0.1585 Y-0.7633 Z-0.9988
N2425 X-0.1621 Y-0.7636 Z-0.9973
N2430 X-0.1655 Y-0.7639 Z-0.9952
N2435 X-0.1685 Y-0.7641 Z-0.9927
N2440 X-0.171 Y-0.7643 Z-0.9897
N2445 X-0.173 Y-0.7645 Z-0.9863
N2450 X-0.1745 Y-0.7646 Z-0.9827
N2455 X-0.1754 Y-0.7647 Z-0.9789
N2460 X-0.1758 Z-0.975
N2465 G0 Z0.2
N2470 G1 X-0.1467 Y-0.8125 F150.
N2475 Z-0.7106 F15.
N2480 Z-1.075
N2485 X-0.1464 Z-1.0789
N2490 X-0.1455 Y-0.8124 Z-1.0827
N2495 X-0.144 Y-0.8123 Z-1.0863
N2500 X-0.142 Y-0.8121 Z-1.0897
N2505 X-0.1394 Y-0.8119 Z-1.0927
N2510 X-0.1364 Y-0.8117 Z-1.0952
N2515 X-0.1331 Y-0.8114 Z-1.0973
N2520 X-0.1295 Y-0.8111 Z-1.0988
N2525 X-0.1257 Y-0.8108 Z-1.0997
N2530 X-0.1218 Y-0.8104 Z-1.1
N2535 X-0.0969 Y-0.8084
N2540 G3 X-0.074 Y-0.7814 I-0.0021 J0.0249
N2545 G2 X-0.0742 Y-0.7785 I0.1246 J0.0103
N2550 G1 X-0.0746 Y-0.7717
N2555 G2 X-0.0748 Y-0.7667 I0.1248 J0.0074
N2560 G1 X-0.075 Y-0.76
N2565 G2 Y-0.7575 I0.125 J0.0025
N2570 G1 Y-0.75
N2575 G2 X0.675 Y0. I0.75 J0.
N2580 G1 X1.0701
N2585 G2 X2.075 Y-0.9936 I0. J-1.005
N2590 Y-0.995 I-0.125 J-0.0014
N2595 X1.07 Y-2. I-1.005 J0.
N2600 G1 X0.675
N2605 G2 X-0.075 Y-1.25 I0. J0.75
N2610 G1 Y-1.2425
N2615 G2 Y-1.24 I0.125 J0.
N2620 G1 X-0.0748 Y-1.2333
N2625 G2 X-0.0746 Y-1.2283 I0.125 J-0.0025
N2630 G1 X-0.0742 Y-1.2215
N2635 G2 X-0.0738 Y-1.2166 I0.1248 J-0.0074
N2640 G1 X-0.0732 Y-1.2096
N2645 G2 X-0.0726 Y-1.2047 I0.1244 J-0.0123
N2650 G1 X-0.0716 Y-1.1977
N2655 G2 X-0.0708 Y-1.1928 I0.1238 J-0.0172
N2660 G1 X-0.0695 Y-1.1857
N2665 G2 X-0.0685 Y-1.1808 I0.123 J-0.0222
N2670 G1 X-0.067 Y-1.1737
N2675 G2 X-0.0657 Y-1.1687 I0.122 J-0.0271
N2680 G1 X-0.0639 Y-1.1616
N2685 G2 X-0.0624 Y-1.1566 I0.1208 J-0.0321
N2690 G1 X-0.0602 Y-1.1495
N2695 G2 X-0.0585 Y-1.1444 I0.1193 J-0.0372
N2700 G1 X-0.056 Y-1.1374
N2705 G2 X-0.054 Y-1.1323 I0.1176 J-0.0424
N2710 G1 X-0.0512 Y-1.1254
N2715 G2 X-0.049 Y-1.1205 I0.1156 J-0.0474
N2720 G1 X-0.0459 Y-1.1137
N2725 G2 X-0.0436 Y-1.1089 I0.1135 J-0.0524
N2730 G1 X-0.0401 Y-1.1022
N2735 G2 X-0.0376 Y-1.0975 I0.1112 J-0.0571
N2740 G1 X-0.0339 Y-1.0909
N2745 G2 X-0.0311 Y-1.0864 I0.1087 J-0.0618
N2750 G1 X-0.0271 Y-1.08
N2755 G2 X-0.0242 Y-1.0755 I0.1059 J-0.0663
N2760 G1 X-0.0199 Y-1.0693
N2765 G2 X-0.0167 Y-1.0649 I0.103 J-0.0708
N2770 G1 X-0.0122 Y-1.0588
N2775 G2 X-0.0088 Y-1.0545 I0.0998 J-0.0752
N2780 G1 X-0.0039 Y-1.0487
N2785 G2 X-0.0002 Y-1.0444 I0.0964 J-0.0796
N2790 G1 X0.005 Y-1.0386
N2795 G2 X0.0089 Y-1.0345 I0.0927 J-0.0838
N2800 G1 X0.0146 Y-1.0287
N2805 G2 X0.0187 Y-1.0247 I0.0888 J-0.0879
N2810 G1 X0.0248 Y-1.0191
N2815 G2 X0.0293 Y-1.0152 I0.0847 J-0.0919
N2820 G1 X0.0358 Y-1.0097
N2825 G2 X0.0405 Y-1.006 I0.0803 J-0.0958
N2830 G1 X0.0474 Y-1.0007
N2835 G2 X0.0484 Y-1. I0.0755 J-0.0996
N2840 X0.0474 Y-0.9993 I0.0746 J0.1003
N2845 G1 X0.0405 Y-0.994
N2850 G2 X0.0358 Y-0.9903 I0.0755 J0.0996
N2855 G1 X0.0293 Y-0.9848
N2860 G2 X0.0248 Y-0.9809 I0.0803 J0.0958
N2865 G1 X0.0187 Y-0.9753
N2870 G2 X0.0146 Y-0.9713 I0.0847 J0.0919
N2875 G1 X0.0089 Y-0.9655
N2880 G2 X0.005 Y-0.9614 I0.0888 J0.0879
N2885 G1 X-0.0002 Y-0.9556
N2890 G2 X-0.0039 Y-0.9513 I0.0927 J0.0838
N2895 G1 X-0.0088 Y-0.9455
N2900 G2 X-0.0122 Y-0.9412 I0.0964 J0.0796
N2905 G1 X-0.0167 Y-0.9351
N2910 G2 X-0.0199 Y-0.9307 I0.0998 J0.0752
N2915 G1 X-0.0242 Y-0.9245
N2920 G2 X-0.0271 Y-0.92 I0.103 J0.0708
N2925 G1 X-0.0311 Y-0.9136
N2930 G2 X-0.0339 Y-0.9091 I0.1059 J0.0663
N2935 G1 X-0.0376 Y-0.9025
N2940 G2 X-0.0401 Y-0.8978 I0.1087 J0.0618
N2945 G1 X-0.0436 Y-0.8911
N2950 G2 X-0.0459 Y-0.8863 I0.1112 J0.0571
N2955 G1 X-0.049 Y-0.8795
N2960 G2 X-0.0512 Y-0.8746 I0.1135 J0.0524
N2965 G1 X-0.054 Y-0.8677
N2970 G2 X-0.056 Y-0.8626 I0.1156 J0.0474
N2975 G1 X-0.0585 Y-0.8556
N2980 G2 X-0.0602 Y-0.8505 I0.1176 J0.0424
N2985 G1 X-0.0624 Y-0.8434
N2990 G2 X-0.0639 Y-0.8384 I0.1193 J0.0372
N2995 G1 X-0.0657 Y-0.8313
N3000 G2 X-0.067 Y-0.8263 I0.1208 J0.0321
N3005 G1 X-0.0685 Y-0.8192
N3010 G2 X-0.0695 Y-0.8143 I0.122 J0.0271
N3015 G1 X-0.0708 Y-0.8072
N3020 G2 X-0.0716 Y-0.8023 I0.123 J0.0222
N3025 G1 X-0.0726 Y-0.7953
N3030 G2 X-0.0732 Y-0.7904 I0.1238 J0.0172
N3035 G1 X-0.0738 Y-0.7834
N3040 G2 X-0.074 Y-0.7814 I0.1244 J0.0123
N3045 G3 X-0.101 Y-0.7586 I-0.0249 J-0.0021 F30.
N3050 G1 X-0.1259 Y-0.7606
N3055 X-0.1298 Y-0.7609 Z-1.0997
N3060 X-0.1336 Y-0.7613 Z-1.0988
N3065 X-0.1372 Y-0.7616 Z-1.0973
N3070 X-0.1406 Y-0.7618 Z-1.0952
N3075 X-0.1435 Y-0.7621 Z-1.0927
N3080 X-0.1461 Y-0.7623 Z-1.0897
N3085 X-0.1481 Y-0.7625 Z-1.0863
N3090 X-0.1496 Y-0.7626 Z-1.0827
N3095 X-0.1505 Y-0.7627 Z-1.0789
N3100 X-0.1508 Z-1.075
N3105 G0 Z0.6
N626 M9
N3110 M5
N3115 G53 G0 Z0.
(Chamfer bottom)
N3130 M1
N3135 T4 M6
N3140 S4000 M3
N3160 G0 X0.5829 Y-1.0333
N3165 G43 Z0.6 H4
N3170 M8
N3175 G4 P1.
N3180 G0 Z0.2
N3185 G1 Z0.0394 F12.
N3190 Z-0.0695 F20.
N3195 X0.5826 Z-0.0734
N3200 X0.5817 Y-1.0334 Z-0.0772
N3205 X0.5802 Y-1.0336 Z-0.0809
N3210 X0.5782 Y-1.0338 Z-0.0842
N3215 X0.5756 Y-1.034 Z-0.0872
N3220 X0.5727 Y-1.0343 Z-0.0897
N3225 X0.5693 Y-1.0346 Z-0.0918
N3230 X0.5657 Y-1.035 Z-0.0933
N3235 X0.5619 Y-1.0354 Z-0.0942
N3240 X0.558 Y-1.0357 Z-0.0945
N3245 X0.5332 Y-1.0382 F12.
N3250 G3 X0.5107 Y-1.0655 I0.0025 J-0.0249
N3255 X1.4423 Y-1.6116 I0.6643 J0.0655 F20.
N3260 G1 X1.4487 Y-1.6088
N3265 X1.4549 Y-1.606
N3270 X1.4611 Y-1.6031
N3275 X1.4673 Y-1.6001
N3280 X1.4735 Y-1.597
N3285 X1.4797 Y-1.5939
N3290 X1.4858 Y-1.5907
N3295 X1.4918 Y-1.5875
N3300 X1.4979 Y-1.5842
N3305 X1.5039 Y-1.5809
N3310 X1.5098 Y-1.5774
N3315 X1.5158 Y-1.574
N3320 X1.5217 Y-1.5704
N3325 X1.5275 Y-1.5668
N3330 X1.5334 Y-1.5631
N3335 X1.5391 Y-1.5594
N3340 X1.5449 Y-1.5556
N3345 X1.5506 Y-1.5518
N3350 X1.5563 Y-1.5479
N3355 X1.5619 Y-1.5439
N3360 X1.5675 Y-1.5399
N3365 X1.573 Y-1.5359
N3370 X1.5785 Y-1.5317
N3375 X1.5839 Y-1.5276
N3380 X1.6055 Y-1.5101
N3385 X1.6263 Y-1.4918
N3390 X1.6463 Y-1.4727
N3395 X1.6655 Y-1.4528
N3400 X1.6825 Y-1.4336
N3405 X1.6989 Y-1.4137
N3410 X1.7144 Y-1.3932
N3415 X1.7291 Y-1.3721
N3420 X1.7419 Y-1.3524
N3425 X1.754 Y-1.3321
N3430 X1.7654 Y-1.3115
N3435 X1.776 Y-1.2905
N3440 X1.7857 Y-1.2694
N3445 X1.7947 Y-1.2479
N3450 X1.803 Y-1.2262
N3455 X1.8105 Y-1.2043
N3460 X1.8177 Y-1.1803
N3465 X1.824 Y-1.1561
N3470 X1.8294 Y-1.1317
N3475 X1.8339 Y-1.1071
N3480 X1.8378 Y-1.0794
N3485 X1.8405 Y-1.0515
N3490 X1.8421 Y-1.0236
N3495 X1.8425 Y-0.9956
N3500 X1.8421 Y-0.9768
N3505 X1.8412 Y-0.9579
N3510 X1.8397 Y-0.9391
N3515 X1.8377 Y-0.9203
N3520 X1.8352 Y-0.9016
N3525 X1.8322 Y-0.883
N3530 X1.8286 Y-0.8645
N3535 X1.8245 Y-0.846
N3540 X1.8199 Y-0.8277
N3545 X1.8148 Y-0.8096
N3550 X1.8091 Y-0.7916
N3555 X1.803 Y-0.7737
N3560 X1.7963 Y-0.7561
N3565 X1.7892 Y-0.7386
N3570 X1.7815 Y-0.7213
N3575 X1.7734 Y-0.7043
N3580 X1.7648 Y-0.6875
N3585 X1.7557 Y-0.6709
N3590 X1.7462 Y-0.6546
N3595 X1.7362 Y-0.6386
N3600 X1.7258 Y-0.6229
N3605 X1.7149 Y-0.6075
N3610 X1.7036 Y-0.5924
N3615 X1.6919 Y-0.5777
N3620 X1.6798 Y-0.5633
N3625 X1.6673 Y-0.5492
N3630 X1.6544 Y-0.5355
N3635 X1.6411 Y-0.5222
N3640 X1.6274 Y-0.5092
N3645 X1.6134 Y-0.4967
N3650 X1.599 Y-0.4845
N3655 X1.5842 Y-0.4726
N3660 X1.5788 Y-0.4685
N3665 X1.5733 Y-0.4644
N3670 X1.5678 Y-0.4603
N3675 X1.5622 Y-0.4563
N3680 X1.5565 Y-0.4523
N3685 X1.5509 Y-0.4484
N3690 X1.5452 Y-0.4445
N3695 X1.5394 Y-0.4408
N3700 X1.5336 Y-0.437
N3705 X1.5278 Y-0.4334
N3710 X1.5219 Y-0.4297
N3715 X1.516 Y-0.4262
N3720 X1.5101 Y-0.4227
N3725 X1.5041 Y-0.4193
N3730 X1.4981 Y-0.4159
N3735 X1.4921 Y-0.4126
N3740 X1.486 Y-0.4094
N3745 X1.4799 Y-0.4062
N3750 X1.4737 Y-0.4031
N3755 X1.4676 Y-0.4
N3760 X1.4614 Y-0.397
N3765 X1.4551 Y-0.3941
N3770 X1.4489 Y-0.3913
N3775 X1.4425 Y-0.3885
N3780 G3 X0.5107 Y-0.9345 I-0.2675 J-0.6115
N3785 X0.5332 Y-0.9618 I0.0249 J-0.0025
N3790 G1 X0.558 Y-0.9643
N3795 X0.5619 Y-0.9646 Z-0.0942
N3800 X0.5657 Y-0.965 Z-0.0933
N3805 X0.5693 Y-0.9654 Z-0.0918
N3810 X0.5727 Y-0.9657 Z-0.0897
N3815 X0.5756 Y-0.966 Z-0.0872
N3820 X0.5782 Y-0.9662 Z-0.0842
N3825 X0.5802 Y-0.9664 Z-0.0809
N3830 X0.5817 Y-0.9666 Z-0.0772
N3835 X0.5826 Y-0.9667 Z-0.0734
N3840 X0.5829 Z-0.0695
N3845 G0 Z0.6
N3850 M5
N3855 M9
N3860 G53 G0 Z0.
N3865 X1.
N3870 G53 Y0.
N3875 M30
Message 5 of 10
LibertyMachine
Give this a shot and see if it's more to your liking. I'm not real crazy about not having the G5x post out on every tool, just thought I'd mention. It's not too bad, provided the control doesn't reset to a different offset upon a reset, power up, or M30. I know a Fanuc can have a parameter set so it holds the active offset. I could see a crash happening, but that's on Fanuc. Can't speak to Haas much. Something to keep in mind..
Another note; just attach the code next time, not copy/paste into the reply box. Makes for a lot of mouse wheel scrolling to get to the end of the post. More helpful to have an attachment that I can open up desperately.
Seth Madore
Message 6 of 10
That is great.  I definitely see what you are saying about the multiple G settings after each tool change.  I guess I could use the search in the program and replace all G55 with GXX but it would always make me paranoid I missed one or it missed one.  The original version of the Haas post from years ago only had one G54 in the beginning and never was an issue.  All I know about Fanuc is it uses G28 which causes a crash on Haas when used wrong!
So there is no way to have a prompt that allows me to make the G5X or G1XX setting I am using?
Thanks again.
-Drew
PS-I had a feeling the cut and paste was similar to reading an email where someone leaves all the old stuff in the reply!
Message 7 of 10
LibertyMachine
To your second question first. The Setup is where you put your workoffset. In your case, a "1" would yield a G55, "2" a G56, etc etc
A Fanuc works just fine with G53. In fact, I much prefer it over the old style G28
Seth Madore
Message 8 of 10
Man that was SO HELPFUL.  I am self taught on the computer end so this was great.  I always wrote my multiple part programs myself.  What a gigantic help this is!
Could you change the post program to leaving the GXX after each tool change now that I will have the correct setting in the set-up folder?
This was so helpful I can barely explain how thankful I am.
Cheers,
Drew
Message 9 of 10
LibertyMachine
No, you can change it yourself Smiley Wink
Look for this section in the .cps:
// wcs   The next line forces out a workoffset at every tool change. STM 12/17/16
  //if (insertToolCall || operationNeedsSafeWorkOffset) { // force work offset when changing tool
   // currentWorkOffset = undefined;
And remove the red // in the next three lines. Leave the // in front of the wcs alone (first line)
Save your file and you should be good to go
Seth Madore
Message 10 of 10
I am very willing to do that.  Again I was very happy to realize I can make these changes.  Super cool.
Thanks again.
