Post process error or intended?
LibertyMachine
Mentor Mentor
Message 1 of 8
LibertyMachine
When posting out any drilling cycle, I get this at the end of the cycle:
G80 M9
Z.05  (this line should not be here)
G53 Z0. M19
M1
The issue I have is with the Z.05 move right after the G80 M9 line. That should not be there. So, if I've got a retract plane of 1" above the part, it will rapid up to that plane, and then right back down to .05" above the part. Haven't had any bad things happen, but it's disconcerting and I'd rather not put that out on the floor.
Furthermore, if I am spot drilling holes of different sizes, how do I get the coolant to persist through the multiple G80 calls?
G43 Z.05 H21 M8 T22
G98 G82 Z-.0466 R.05 P500 F13.1
Y-.2375
G80 M9   (the M9 should not be here)
G0 Z.05   (again, this line should not be here)
M8          (if the M9 can be prevented from being output, then perhaps the M8 won't populate?)
G0 X2.65 Y-.2425
Z.05
G98 G82 Z-.0556 R.05 P500 F13.1
X3.15
G80 M9
Z.05   (again, this should not be here)
G53 Z0. M19
M1
If this is something that can be controlled in the Fusion environment, that would be great. If it requires a post modification, then I will toss it on the CAMforum
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Replies (7)
Message 2 of 8
Steinwerks
Can you share an example part and your post processor here?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 8
LibertyMachine
http://a360.co/1TOIPiW
Seth Madore
Message 4 of 8
jeff.walters
That looks like one of our standard post setups. If it doesn’t work on your machine you can modify it to not out put it. Did you get the post from us?
Jeff Walters
Senior Support Engineer, CAM
Message 5 of 8
LibertyMachine
It was a standard Fusion post. I edited it as far as I could go quite a while ago and then Laurens-3D did a few things to it, and then someone else, and then even more later on, so on and so forth
Seth Madore
Message 6 of 8
LibertyMachine
Should I kick this over to the CAMforum for post editing, or are those moves inherent to Fusion?
Seth Madore
Message 7 of 8
jeff.walters
yes sir they would be able to help you here
http://forums.autodesk.com/t5/post-processors/bd-p/218
Jeff Walters
Message 8 of 8
LibertyMachine
Thanks again @jeff.walters
Seth Madore
