I had a part to do recently that I ran into a slight annoyance. I got through the part, but now that I have a moment to breathe, figured I'd throw this out to the community.
It was a 9" round plate with an 8-hole bolt circle on a 7" diameter. I drew up one hole at 12 o'clock and then used the circular pattern. When I programmed it, I noticed that the parent hole was entering and exiting from the 3 o'clock position. However, the subsequent 7 holes did not follow this logic and instead seemed to be entering at the 3 o'clock position, plus (or minus) whatever angle it had been rotated to.
Now, this isn't a HUGE issue, but when you are proving out your code, it makes it more of a chore to readily determine if your code is proper, at least on a visual/mathematical level. Is there a simple method that I have perhaps overlooked to force out entrance and exit points, or must I physically select a quadrant of the circle to make it work?
Furthermore, it does actually make for larger nc files, which is an annoyance with my new machine, and often problematic with my older Matsuura
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
