Post Failing, changing program name fixes problem
caleb5BVNG
caleb5BVNG
I have a program that is failing on post, which has previously posted fine.
Changing the name fixes it, but there's no reason why it should.
Program Name and File Name is PPC100532OP50, which it needs to be for various reasons.
Trying to post gives me errors like:
  • "invalid toolpath" on a perfectly fine toolpath, i.e. changing the Z height fixes that and gives an error somewhere else.
  • "Error: Failed to invoke 'onParameter' in the post configuration." in just a normal rapid move in an operation copied from one earlier that posted fine.
If I change the name from PPC100532OP50 to PPC100532OP5 (one character shorter) everything works fine.
In the same file, I have another program called PPC100532OP60, which also posts fine.
I have half a dozen other programs with the same length name and just 1 or 2 characters different that post perfectly fine.
The program name shows up a few times in the program, nowhere near where the program is failing to post.
What is going on??? Where do I even start looking?
viacheslav.shapilov
Hello, @caleb5BVNG . This sounds interesting. Could you share your project/post? You can send them in private message. I can try to reproduce it.
Viacheslav Shapilov
Developer Technical Services
Autodesk Developer Network
