Message 1 of 10
Incorrect cut size
Good morning,
I am new to CAD and am still learning how every thing works in Fusion so I have the hobby version for now.
I picked up that when I was cutting with the CNC using the adaptive clearing function i was a couple of millimetres out on the designs i was cutting. So on a friends advice and on his CNC I did a test using three basic circle’s each with a different diameter. The same tool and machine were used to cut using Fusion and another CAD program. When cutting the NC file from fusion I get a discrepancy of 2mm on the X & Y plane Z is correct, with the other CAD program the dimensions were correct. So don’t think it is a machine problem. (other CAD program is used often on the CNC with no problem)
As mentioned I'm still learning. What am I missing and how do I go about rectifying this problem?
The controller the CNC is using is a RichAuto A11 .
Kind Regards
Gareth
