Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
PLEASE HELP! Chamfer Bug!
Message 1 of 11
This morning Fusion updated with the new January 2017 patch and since this update all my chamfers are posting out with a F0. in some of the G1 commands.  (See attached file).
I know it definitely is not the post processor as I was making parts yesterday just fine.  I have heaps of parts to make and simply do not have the time to edit all the F0.'s to the correct values.
Fusion Team, please fix this ASAP!!!!  I am in trouble.
Kind regards
Grant Nicholas
Replies (10)
Message 2 of 11
Steinwerks
I'd bet this is because you're using a Drill that doesn't have a feedrate in its definition. Change that to a Chamfer Mill tool defined the same and it should fix it.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 11
I bow to your God like powers of deduction!  Kudos added!!!!!!
Thanks so much I do really appreciate it.  Weird thing is how it has always worked till now.......?
Cheers
Grant
Message 4 of 11
Steinwerks
Are you using a generic post or a custom one? Is the tool defined as a Spot Drill specifically, or just a Drill but short? Spot Drills, Counter Sinks and Center Drills have cutting feedrates whereas plain drills do not so it could be a definition issue in this case.
Neal Stein
Find me on:
Message 5 of 11
Generic Tormach Path Pilot Post Processor.
I have always had it setup as a Spot Drill which contains a cutting and ramp feed rate.  It would appear that something has changed as it requires lead in and out feed rates now too????
Cheers
Grant
Message 6 of 11
Steinwerks
Would you be willing to Export and share your part file here? I'd like to see what's getting output to see why a Spot Drill isn't working, because it should as best I can tell so far.
Edit: nevermind, I've figured where it's coming from. There is no Lead-in or Lead-out feedrate applied to the Spot Drill and so it defaults to zero. There might be a way to override this in the post, but it's going to be a much safer bet to simply define a Chamfer Mill.
@jeff.pek is there a plan for this? I don't think this is the first time this has come up.
Neal Stein
Find me on:
Message 7 of 11
jeff.pek
I'll look into this. I can't answer offhand right at the moment.
  Jeff
Message 8 of 11
@jeff.pek I have seen that this was a problem in HSM Inventor to about a month ago.
Will be nice to see a fix for it soon.
Cheers
Grant
Message 9 of 11
Message 10 of 11
onellesen
Thank goodness this was here, I have hot parts and fusion force updated then that feed issue occurred, changed to chamfer mill not spot drill and Viola!
Message 11 of 11
Oh man, I can't tell you how glad I am for finding this post.  I thought I was going crazy.  Changing the tool type to chamfer mill did the trick.  All is right with the world.  Well, my CNC world that is...
Thank you!
